07-18-2016, 04:46 PM
#61
No OC magic "thingie" you thought of on the bottom or anything? Come on OC, you are like MacGyver I thought you would have had something special to keep it from sliding on any surface. Okay, cool. Thanks, maybe because it is heavier, although the Trailer Aid is pretty hefty also.
D_B Travelers - 39 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 – 1996)
07-18-2016, 04:55 PM
#62
My jack for my TV works just fine for both.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
07-18-2016, 06:11 PM
#63
Originally Posted by D_B Travelers
No OC magic "thingie" you thought of on the bottom or anything?...
Coefficient of friction between wood and plastic is not magic.
07-18-2016, 06:17 PM
#64
Had 2 flats on a triple axle cargo trailer, same side, and used a 12ton bottle jack and 19.8V cordless craftsman impact wrench. What a life saver. Changed flats in 10 minutes. Hardest part was getting spares out of storage.
2018 Forester 3011 DS
07-18-2016, 07:36 PM
#65
Left Coast
Some folks ride the brake when trying to pull up on block, causing it to skid....wait till your part way up .....
Sent from my XT1585 using Tapatalk
07-18-2016, 08:16 PM
#66
If you have a dual axle, just get the Trailer Aid. Works like a charm.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
07-19-2016, 08:31 AM
#67
And...thank you Mr. Science! Just thought with all your ingenuity you probably had something special on the bottom of the wood ramps. I have thought and been wrong before...oh boy!
07-19-2016, 08:44 AM
#68
DB,I attacked 1/4" Plywood to the bottom of our Plastic ramps,not so much for friction but "Bigger Footprint" in sand,rocks,gravel"! Scooting is not a issue! Youroo!!
07-19-2016, 08:50 AM
#69
I wasn't trying to be snarky, I just haven't seen the need to add anything.
07-19-2016, 08:56 AM
#70
Left Coast
Could always make a 'shoe' with cleats that could slip on when needed....
07-19-2016, 09:01 AM
#71
I know you were not, I took it in the jest you intended. And hopefully you realized I was having fun right back. You always seem to have done something to camping gear to make it perform better, so I was just picking at you because you had not modified your Trailer Aid to "OC's Super Trailer Aid".
07-19-2016, 09:34 AM
#72
...so I was just picking at you because you had not modified your Trailer Aid to "OC's Super Trailer Aid".
I was at a trailer shop that had Trailer Aids and ask if I could measure one and got permission to do so. Being the cheapskate that I am, went home and made my own. Mine is maybe 1" wider, I don't remember. Only used it one time to see if it worked on our concrete driveway and it did. It's been on the back bumper undisturbed for about 3 yrs now.
07-19-2016, 09:48 AM
#73
NICE shop! No wonder you can MacGyver anything and everything!
07-19-2016, 09:55 AM
#74
I usually remains totally cluttered. Have to leave TOWTA's old junker outside for any project of any size. I took 25 pictures of the contents for insurance purposes. Way too many to post here.
07-19-2016, 06:30 PM
#75
Yup! No gimmicky ramps for me. A basic bottle jack is all you need!
07-19-2016, 09:30 PM
#76
Dexter says to jack the trailer up from the frame of the trailer or damage to the axles or suspension system could occur. I suspect this is CYA. I've always used the axle close to or under the U clamps.
I read on another forum that someone said a dexter rep advised not to use the trailer aid as it could bend the axle. Maybe that's why they say not to jack from the suspension or axle?
It's a long way up to the frame. I guess one could block the bottle jack up with some 4 x 6's. I've been using a jack with a small strip of channel iron to distribute the weight a little. Haven't had any issues.
USMC 68 -70
07-20-2016, 08:50 AM
#77
I do one of two things:
1. Call Coach Net to come out replace the tire.
2. Hit my six point level up and lift the tire off the ground, put jack stands under the the frame, and change tire.
What I won't do. Is put a bottle jack under the frame along side the highway with big trucks going by rocking the 5er and on uneven ground to change a tire.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
