Old 04-23-2012, 06:32 PM   #11
Brigitte
boubou's Avatar
Originally Posted by RJHuser
Wow - That's a heavy truck, or the dogs aren't that small (I won't say anything about the two people)!
(Sorry - I'm just joshin' with you, I couldn't resist!)
Lol, just caught that! A little too loose on the keyboard! Lolo 6173 lbs. even this makes no sense. Do cat scales weigh like this? Or do they round numbers off?
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 04-23-2012, 06:46 PM   #12
cootr68's Avatar
Cat scales round off by tens.
1997 Sierra m-27fls tt
1999 Pontiac T/A
2006 flstn Deluxe
2004 Polaris 330 magnum
Bear the Labrador
cootr68 is offline   Reply With Quote
Old 04-23-2012, 06:55 PM   #13
(Kim)
Labzy's Avatar
The GVWR on our Ram is 6800lbs and our payload is 1105lbs, subtract the 2 and you have a 5700lb truck. Are you sure your truck weight is 5400?
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 04-23-2012, 07:11 PM   #14
Herk7769's Avatar
What a PITA this was
It has been a while since I used this calculator so here it goes:
2010 Dodge Ram 1500 Dodge Ram 1500 Car Buying Guide at CARandDRIVER.com- 2010 Dodge
Based on 2010 RAM 1500 Laramie QC with 5.7L Hemi and 3.92 gears
GVWR - 6700
FRONT GAWR - 3900
REAR GAWR - 3900
CURB - 5489
Curb Front - 3199
Curb Rear - 2290
Max Payload available 6700 GVWR - 5489 Curb = 1211 Pounds
Gross Combined weight rating - 13,000
Max Trailer Wt with WD hitch - 7211
MAx tongue Weight with WD hitch - 865
BOX 1 - 6700
BOX 2 - 13000
BOX 3 - 7211
BOX 4 - 865
BOX 5 - 3900
Here is where we both run into problems
So I used the CURB weights to figure it out
BOX 6 - 5489
BOX 7 - 2290
Actual Weight of the camper is asked here.
I left these blank so it would calculate the maximum size camper I can tow with these numbers
BOX 8 - BLANK
BOX 9 - BLANK
Safety Margin (a percentage less than maximum)
BOX 10 - Zero
Load Ratio of TT weight to Tongue 9% - 15% range
BOX 11 - 15%
Calculated maximum trailer weight = 5,767 pounds at a tongue heavy 15% of TT weight - or 865 pounds
BOX 11 - 9%
Calculated maximum trailer weight = 7,211 pounds at a tongue LIGHT 9% of TT weight or 865 pounds
BOX 11 - 13% (optimum)
Calculated maximum trailer weight = 6,654 pounds at a tongue wt of 13% of TT weight or 865 pounds
So, now we use your "actual weights" not curb weights.
BOX 1 - 6700
BOX 2 - 13000
BOX 3 - 7211
BOX 4 - 865
BOX 5 - 3900
BOX 6 - 6175
BOX 7 - BLANK
Again I left these blank so it would calculate the maximum size camper I can tow with these numbers
BOX 8 - BLANK
BOX 9 - BLANK
BOX 10 - Zero
BOX 11 - 15%
Calculated maximum trailer weight = 3500 pounds at a tongue heavy 15% of TT weight - or 525 pounds
BOX 11 - 9%
Calculated maximum trailer weight = 5,833 pounds at a tongue LIGHT 9% of TT weight or 525 pounds
Calculated maximum trailer weight = 4038 pounds at a tongue wt of 13% of TT weight or 525 pounds
So putting 686 additional pounds in the truck reduces the available payload to a point where it reduces what you can tow based on the percentage of tongue weight available. Additional weight placed IN the truck is leveraged by the factor used to balance the camper. Every pound put in the truck reduces the available camper you can pull by 6.7 pounds (at 15% tongue load) at 9% tongue load every pound in the truck subtracts 11.1 pounds of allowable camper weight.
Easy numbers at 10% tongue load; for every extra pound in the truck you reduce the amount of camper you can tow by 10 pounds.
Did this help you?
HAM CALLSIGN - KC3FFW
Old 04-23-2012, 07:17 PM   #15
Herk7769's Avatar
Oh, more bad news.
All these numbers REQUIRE 17 inch wheels.
The 20 inch wheels have lower tow ratings.
but they LOOK cool
Old 04-23-2012, 08:27 PM   #16
Brigitte
boubou's Avatar
6700 (my ram GVWR minus 1263 payload: 5437
Superglide 2700
Timbrens
Old 04-23-2012, 08:32 PM   #17
Brigitte
boubou's Avatar
Originally Posted by herk7769
Oh, more bad news.
but they LOOK cool
Lmao! They are cool number aren't they?
So, bottom line for my application is:
Do not put anything in the truck, just load the trailer right up )))
Problem solved
i had pillows ( isn't that heavy!), cooler, dog stuff, books, computer etc... In the truck with us. It all adds up. No more. Stricked essentials travelling in truck i. The future. Rest goes into the trailer.
Superglide 2700
Timbrens
