Forest River Forums
Sunline User Photos
Old 09-30-2011, 08:52 PM   #1
Brigitte
boubou's Avatar
changing gears tt weight calculator
what am I doing wrong?
I don't know if I am doing anything wrong on that site but once I enter all the numbers for my 2010 Dodge Ram 4X4 1500 with the Hemi, it looks as if I can tow close to 7000 lbs.
When I enter the Tow vehicle RGAW which is the actual gross vehicle weight of the tow vehicle without trailer attached; in that box, I entered the number that was taken from the weigh in. we had two of us, two small dogs, hitch and a full tank of gas 61730 lbs . The program then tells me my maximum trailer should be 3513 lbs with a 527 lbs tw.
What is wrong here? it just seems wrong
When I weight the truck and trailer ( which weigh in loaded around 5700 lbs ), I am 80 lbs over my GVWR of 6700 but this weight calculator seems way off for some reason and I cannot make any sense of it.
Shasta Revere 21FBS LE
2010 Dodge Ram SLT 1500 QC 4X4 HEMI
Sheltie, Chihuahua and a Mr. Mutt
Kingston, Ontario
Days reserved 2012 (so far) 30 Days camped 2012:
boubou is online now   Reply With Quote
Old 09-30-2011, 09:18 PM   #2
Welcome to the world of 1/2 ton towing. Confusion abounds. Most people are convinced that since they bought a truck (1/2 ton) they should be able to tow the world. In real life depending on what rear end ratio your grocery getter has you should be able to safely handle between a 5000 and 7000 pound trailer. 10% of that is around 700 pounds. But with a properly setup equalizer type hitch some of that weight will be transferred to the front axle and you will be just fine.
donn is online now   Reply With Quote
Old 10-01-2011, 12:41 AM   #3
Moderator
I don't want to be picky, but you typed in post #1, original post "When I enter the Tow vehicle RGAW which is the actual gross vehicle weight of the tow vehicle without trailer attached;"
Notice the RGAW, to me that means rear gross axle weight, not the GVWR which is the gross vehicle weight rating. Are you putting in the right numbers? Did you miss type something here? Just trying to help.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
windrider is offline   Reply With Quote
Old 10-01-2011, 06:09 AM   #4
Brigitte
boubou's Avatar
This is why I asked the question... I MUST be mixing the numbers up
so the GVWR is 6700
Tow vehicle RGAWR is 3900 (so is the front)
and
Tow vehicle RGAW
Enter actual weight of tow vehicle's rear axle (Rear Gross Axle Weight), without trailer attached. That would be the number of the truck on the scale with people and dogs in it. So the number that came up on the CAT scale yellow sheet, I took the number from Drive Axle with is 2644
Are these the right numbers in the right places?
I don't have time now, but if not, of for the sake of clarity, I'll take a pic of the CAT yellow sheet and you can show me what I am doing wrong
Kingston, Ontario
Old 10-01-2011, 06:13 AM   #5
Lou Amadio
herk7769's Avatar
Randy is correct.
RAGW is the actual weight of your rear axle (WITHOUT the trailer attached); not the entire truck in that spreadsheet.
Travel Trailer Weight Calculator
Right under RAGW it explains it.
RGAWR is your truck's maximum rear axle rating.
GVW (GTW) is your camper's Maximum "legal" Gross Weight Rating
GVWR is yout truck's maximum gros weight rating.
Actual Tounge weight is found by disconnecting the trailer while on the scales with the wheekls on one plate and the front skid on the plate in front of it.
It can also be calculated PROVIDED you take the WD bars (if equipped) OFF the hitch. Then weight the truck and camper together (with no WD bars connected); then drop the trailer and come back and just weigh the truck. Subtract the truck's weight (unhitched) from the truck's weight hitched (WD bars disconnected) and that will give true tounge weight as well.
Tounge weight can also be found in your drive way by using the instructions in the link below and a bathroom scale.
Tongue Weight Scale
Don't forget to take a reading of the board and pipe on the scale first (Tare Weight) and subtract that weight from the weight of the camper's tongue when added.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 4)
herk7769 is offline   Reply With Quote
Old 04-23-2012, 10:21 AM   #6
Brigitte
boubou's Avatar
I was reading this again and realized the mistake in calculation.
The changing gears program prompts me to enter :Tow vehicle GVW
Enter actual weight (Gross Vehicle Weight) of tow vehicle.
Now, if I enter the number that is on the door, no problem, if I enter 5400 lbs with me and fuel, same, no problem. But if bump it up to 6173 lbs with full load, then the numbers tumble down.
Kingston, Ontario
Old 04-23-2012, 11:23 AM   #7
Lou Amadio
herk7769's Avatar
This does not sound right still.
The program has boxes from top to bottom.
Put the numbers in order here from top to bottom so we can check the entries.
Lou
Old 04-23-2012, 05:37 PM   #8
Brigitte
boubou's Avatar
Lou, these first numbers are with empty truck at 5400 lbs
Item Qty Units Weight (lb)* Weight (kg)*
Tow vehicle GVWR
Enter Gross Vehicle Weight Rating as provided by tow vehicle manufacturer.
6,700 lb
Tow vehicle GCWR
Enter Gross Combination Weight Rating as provided by tow vehicle manufacturer.
14,000 lb
Tow vehicle maximum loaded trailer weight rating
Enter rating as provided by vehicle manufacturer.
8,450 lb
Tow vehicle maximum tongue weight rating
Enter rating as provided by vehicle or hitch manufacturer, whichever is less.
1,045 lb
Tow vehicle RGAWR
Enter Rear Gross Axle Weight Rating as provided by tow vehicle manufacturer.
3,900 lb
Tow vehicle GVW
5,400 lb
Tow vehicle RGAW
Trailer GVW (or GTW)
Enter actual weight (Gross Vehicle Weight or Gross Trailer Weight) of trailer.
5,800 lb
Trailer tongue weight
Enter actual tongue weight of trailer.
750 lb
Calculation Results
Maximum Trailer Weight
This is the maximum trailer weight based on the most restrictive tow vehicle ratings provided (tongue weight rating at 15% of trailer weight).
6,967 lb
Maximum Tongue Weight
This is the recommended maximum tongue weight, based on 15% of the calculated Maximum Trailer Weight.
1,045 lb
all is good, until I start adding people and gear into the truck. Bump it up to 6000 lbs (appx, have to go weigh again, last weigh was 6100 lbs with nothing in the bed, so makes no sense)
all I changed is the TV GVW
the results:
Trailer GVW exceeds Maximum Trailer Weight. The provided trailer GVW (or GTW) exceeds the calculated maximum trailer weight. You should either lighten the trailer or provide additional information for a more accurate calculation.
4,667 lb
Tongue weight exceeds Maximum Tongue Weight. The provided trailer tongue weight exceeds the calculated maximum tongue weight. You should either lighten the trailer or provide additional information for a more accurate calculation.
700 lb
if I put in 6175 for tv like I think it was weight at, I get a maximum trailer at
This is the maximum trailer weight based on the most restrictive tow vehicle ratings provided (GVWR - GVW remainder for tongue weight at 15% of trailer weight).
3,500 lb Maximum Tongue Weight
525 lb
Crazy.
The way I read this, add a couple hundred pound in the truck, loose a couple thousand pound in the trailer.
Kingston, Ontario
Old 04-23-2012, 06:22 PM   #9
RJHuser's Avatar
Wow - That's a heavy truck, or the dogs aren't that small (I won't say anything about the two people)!
(Sorry - I'm just joshin' with you, I couldn't resist!)
Rick & Debbie; Brandy, Dexter, & Fritz (The Doxie "Kids")
2011 Rockwood Windjammer 3001W
2009 Chevy Silverado 2500HD, 6 L Gasser; 12K Equalizer Hitch
RJHuser is offline   Reply With Quote
Old 04-23-2012, 06:29 PM   #10
Brigitte
boubou's Avatar
That's the reason I need to weigh truck again. There is a tonneau cover and running boards. 4x4 with 20 inch wheels.
I weigh 135 , spouse is 175, a chihuahua, a 25 lbs sheltie and another 13 lbs dog. I even loaded the truck very lightly, nothing in the bed.
Kingston, Ontario
» Online Users: 594
124 members and 470 guests
2000XLifted, 4Jeeperz, 5Galvs, autorot8, bean, bear17, Bearcat55, biken201, bikendan, bob7794, Borwick, brookside, Busman1947, buzzmonster, Cascade Bob, cat1956, cdbus, chiro, chof16, comfun1, condo, Cowracer, cstover, cyclepuck, DAISY BOYKIN, danred, dasimser, ddavis662, deerslayer, DGrissom, dimurrrw, DonG, donn, Douglasdh62, Drmstx62, DSN46, dunnnc, elind, forthefunofit, FreedomTracker, frfan, gbpacker, GeorgieGirl, Gizzerd, Gman88, gmurrell, Gollum, Hammertat, Happy Vibe, icebrew, iscotty123, isz, JamesR, jasni, Jeep4Two, JJones, jmswms, JoeR, joess, Joker, jphillips1075, jrcouture, judy3972, jwuertz, kegoneill, kjoh75, LFugate, lmcleister, louincal, lowbubba, maggiek, mhartzel, micalo, Mr. Legato, mrmurph, MT28rk, mtl roofer, mtnguy, NanaKaren, NancyTX, pandkm, pappcam, Piston, pixleys, Playtime III, plcrph2, PrairieBoy, pwrplay, Ragin Cajun, Redheaded blue tick, ret2006, rickthelen, rkswyo, rob and lisa, Rogue69, rstewart06, russpat, rwzahm, SabreSam, sbond, shineysideup, SimchaSabre, Skippkon, skippy31405, snowbrid, softwarejoe, southernsky, spike, Stinger, Tech Admin, texashatter, tgarner2000, thaithco, Titleguy, tmmar, TN_Jeeper, Triathletedave, Triguy, viper48, VTX Al, wakamicamper, whj77372, william.migues, wvfireboss
Most users ever online was 996, Yesterday at 11:04 AM.
Close [X]
