Old 06-20-2013, 01:47 PM   #1
charging tow vehicle
When my Windjammer 3401 is plugged into my F150 and the trailer is plugged into shore power will the trailer supply charging voltage to the truck? The reason for my question... if I have a dc cooler plugged into the truck overnight, will the trailer connection keep the truck battery from going dead?
David Cournoyer
2015 F250 SRW 4x4 Crew Cab Platinum
6.7L Powerstroke V-8 Diesel
2013 Rockwood Windjammer 3001w Diamond
Handydc is offline   Reply With Quote
Old 06-20-2013, 01:54 PM   #2
what year is your f150? for many years ford uses a relay for battery charge lead. it will only be connected when the key is on. so in other words.. no.
18 3500 denali duramax cc srw
silverback 31b2
skidoonut is offline   Reply With Quote
Old 06-20-2013, 01:56 PM   #3
2011ecoboost
David Cournoyer
Old 06-20-2013, 03:07 PM   #4
avolnek's Avatar
Most of the current trucks are set up with a constant 12v straight off the battery to the RV plug. If you use a volt meter and measure the + and - pin while the truck is off and you have 12v then yes it will charge as yours is connected straight to the battery. I haven't ever personally seen any use a relay to switch the lead on and off but I suppose it is possible. In which case there wouldn't be 12v when the truck is off and the truck wouldn't charge...
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 06-20-2013, 03:13 PM   #5
Excellent suggestion, thanks.
David Cournoyer
Old 06-20-2013, 03:19 PM   #6
Wanna Be Camper
SaskCampers's Avatar
There was a recent discussion on here about this very thing on Ford trucks and they have used relays in Fords since at least the late 90's. My 11 F250 has one as well.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 06-20-2013, 03:21 PM   #7
avolnek's Avatar
This is very possible... If this is the case though and you are looking to have a constant 12v to the rear it would be simple enough to by pass the relay... I will look into and see if I can find anything...
