01-09-2017, 06:58 AM
Chevrolet Silverado Steering Issue
Just a heads up for anyone using a Silverado as a TV. First, don't get me wrong, I love my truck and its doing its job. This is more of a warning. If you get steering resistance while performing a slow speed turn such as in a parking lot; take your truck to the dealer ASAP.
In August, we started feeling the tiniest "pop". I wasn't even sure it had happened at first. After about 3 episodes over several months, I took it in but local dealer in October who said nothing wrong. Fast forward to December and it is now predictable and can be caused at will. Took it back to another dealer and they opened up the steering assist system and sampled fluid. Its full of metal shavings. The pump and gear box are basically destroying themselves.
If we had continued, we would have been cruising down the interstate with 13000 LB on our tail, gone to pull into a Cracker Barrel or some such place; made a right turn on an exit ramp, the steering would have locked and lost half our braking. Our next thought would be "I don't remember parking upside down cross ways on the interstate"
Come to learn that there is a TSB and is apparently one step away from becoming a full blown recall. It will be fixed as warranty work. It has nothing to do with mileage or usage, it is a parts/design failure.
2015 FR3 30DS Motorhome
2017 PrimeTime Crusader 315RST 5th Wheel
2002 Thor Chateau Sport Class C
Good SAM # 807510227
FROG # GA-0056-236
FMCA # F471293
01-09-2017, 07:17 AM
Georgia Rally Coordinator
Thanks for posting the info. Mine was repaired when I took it in for service as they had the TSB. I always ask if there are any pending issues when I take my truck in. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
01-09-2017, 08:02 AM
What year? Do you have the TSB#?
01-09-2017, 08:06 AM
Will look for number associated with mine but affects multiple years. Mine is 2014. Not sure if one TSB for multiple model years or what.
FROG # GA-0056-236
FMCA # F471293
01-09-2017, 08:20 AM
Yep... I'm also interested.
The TSB Mr Havercamp listed for headlight issues covered multiple years.
01-09-2017, 08:30 AM
Interested myself...is it for 2500's only?
I have had some interesting steering wheel feedback...so you have peaked my interest...
2016 Prime Time Crusader 294RLT
2021 RAM 3500 Laramie Mega HO\CTD, CC, 4x4...ect
Days Camped in last 3 years - 79
Planned Days in 2021 - 50
Days Camped in 2021 - 0
01-09-2017, 08:34 AM
May be #3386. Mine felt like a small pop initially. As time wore on, pops worked up to 2-3 second steering lock ups. Don't think it's specific to 2500s.
FROG # GA-0056-236
FMCA # F471293
01-09-2017, 11:15 AM
On the Chevy forums, the steering issue is a big issue. It looks to be for both the 2500 and 3500. Not sure how far back it goes, but a big problem with the 2016's. This is the first I have read about the locking up, as most are for excess play. There is a redesigned steering box out now (at least a new part#), that people are putting on. Some of the fixes and TSB's have been for loose adjusting screw or loose pitman arm. I had them loctite my adjusting screw on my 2500 (per a TSB), and so far no problems. I am also not a fan of the electronic steering assist. Much rather not have it.
TSB's for both 2016 2500 and 3500 (I am sure not a complete list):
PIT5501B, PIT5501A and SB-16-NA-109
A number of people are making sure NHTSA is well aware of the problem as Chevy is doing the normal minimum fix possible.
Good website for checking TSB's on Chevy's: http://www.chevroletproblems.com/tsbs/
Mark
01-09-2017, 02:38 PM
Agreed lots of different issues re steering. This is definitely pump/gearbox related.
FROG # GA-0056-236
FMCA # F471293
01-09-2017, 02:51 PM
The SB doesn't show up on the NHTSA's website, at least not yet.
2011 Traverse LT, 3.6L, FWD
01-09-2017, 02:52 PM
I have a 2016 Silverado 3500 HD Duramax Dually. The truck had 4800 miles on it when I found a slight drip under the engine compartment. After checking I found fluid on the pitman arm. Dealer said there was a T.S.B. that called for replacing the shaft but that they were on B.O. from G.M. About 3 weeks later they replaced the PS gear, Pitman shaft. As soon as I got behind the wheel leaving the dealer I found that the steering was much tighter. My previous truck was a 2012 Chev 2500 HD gas engine and I found no problems with that trucks steering.
01-09-2017, 04:02 PM
2013 .500HD duallt
Guess I win - no recalls listed at all for my truck, with 50,000 + miles. I also think I have electric steering
Kayo
2014 Primetime Sanibel 3051 pulled by a 2013 Chevy Silverado 3500HP dually diesel. Full timers wince 2003 with DW of 53 year. NPS Park Ranger
01-09-2017, 04:47 PM
Are GMC's affected
GMC Denali 2500HD 4x4
Columbus 381 FLC 2016
Flagstaff Ultralite 29 RLSS
2013 35 nights, 2014 105 nights, 2015 123 nights, 2016 18 nights 🙁
01-09-2017, 04:52 PM
Most likely, only difference a tech told me was the grille, hood and badges
01-09-2017, 05:33 PM
A TSB is not as high up the chain as a recall. Most likely, an owner will get a notification about a recall... but you have to dig up TSBs yourself. I had a TSB corrected on my truck 3-4 weeks ago only because I saw info. on it here. I received no notification from GMC - and when I got it fixed, I had to state what was my issue before they would fix it.
01-09-2017, 06:24 PM
The new pitman shaft is for the 2016's only. 2500/3500
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
01-09-2017, 06:31 PM
How can this be??? Chevy claims JD Power says the Silverado is tops in New Car Reliability!
Oh, wait - as soon as you drive it off the lot, it's not a new car anymore!
(Good thing I didn't buy based on JD Power!)
01-10-2017, 10:43 PM
Ok so I work for GM and looked up the TSB. It is #PIT5501D. Only applies to 2016 Chevy Silverado and GMC Sierra 2500/3500. Does not effect other models or years of trucks. Have only ever seen 1 of these in our shop. Steering feels loose when driving was the customer's concern.
01-11-2017, 01:07 AM
Googled the TSB and came up with this (Post #41):
2016 GM 2500HD steering loose/play - Page 5 - Chevy and GMC Duramax Diesel Forum
If you go to the first page of the link above, there's another link to this:
2016 Silverado 2500HD Steering woes - Page 8 - 2015 / 2016 / 2017 Chevrolet Silverado & GMC Sierra 2500/3500 HD - GM-Trucks.com
01-11-2017, 02:06 AM
Good information on recalls and TSBs. Thanks.
Please remember to stay away from political comments. Site Team has had to clean this thread up once already.
2014 Sabre 34REQS-6
