Old 02-18-2014, 06:00 PM   #1
Chevrolet Tahoe or Chevrolet 1500?
I am looking to purchase either a Chevrolet Tahoe or 1500 4Door truck. Both are 5.3 l engines. My camper is a 27' Forest River Salem. It weighs about 5300 lbs dry weight...gross vehicle weight 7300 lbs...Double Axle. Which would be better to pull my camper? Both have the same motor...I am new to camping and I just want to be informed. I also would prefer NOT to buy a larger vehicle. Thanks for you help...
Tony Smith is offline   Reply With Quote
Old 02-18-2014, 06:12 PM   #2
dannyabear's Avatar
Truck because of longer wheelbase will be more stable
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 02-18-2014, 06:32 PM   #3
Moderators' Assistant
bikendan's Avatar
plus the truck will have a much higher towing capacity, hitch capacity, payload, and stronger suspension.
a Tahoe will be heavier, have less everything for towing and will have terribly soft suspension for towing.
comparing a full size SUV, to a full size pickup, isn't even fair when it comes to towing.
and the fact that they have the same engine, is only one piece of what it takes to tow safely.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 02-18-2014, 06:34 PM   #4
Tony - Whichever one you get, MAKE SURE you know what it's actual towing capacity is for the EXACT version of the truck you intend to buy. Don't let the dealer tell you "Oh, any 1/2 ton pickup can tow that." That's the biggest lie in the industry, and he WILL use it on you.
For example, my 2009 Silverado Owners Manual lists towing capacities for 99 (count'em - NINTEY NINE!!) different permutations (cab, engine, rear end gearing, transmission, cooling packages, towing packages, long/short bed, etc.) of the Silverado 1500 ranging from 4,400 lbs to 13,000 lbs. (There are additional listings for the 2500 and 3500.) There's an 8,600 lb spread between 4,400 and 13,000 lbs!!! Mine is good for 7,500 lbs.
So make sure the exact vehicle you intend to purchase can handle your TT.
1988 Coleman Sequoia - popup (1987-2007)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
Old 02-18-2014, 06:35 PM   #5
davel1971's Avatar
definitely the truck over the SUV
David & Lynn
Old 02-18-2014, 07:04 PM   #6
Crusadernoob's Avatar
I used to tow a 4,000lb TT with a Tahoe, and I would strongly suggest the truck, the Tahoe did ok but even with a 4 point sway control it wasn't great. We towed long distances would never do it again, we bought a 2500HD then upgraded to a 5th wheel.
2006 2500HD Duramax CCSB 2WD
2014 Crusader 285RET
Nights camped in 2013 - not enough!
Nights camped in 2014 37
Nights camped in 2015 40
Nights camped in 2016 35
Crusadernoob is offline   Reply With Quote
Old 02-18-2014, 07:55 PM   #7
I have a Tahoe which came factory with the trailering auto leveling system with a gear ratio designed for pulling trailers and pulled this same trailer you are looking at with no problems for years. That being said, I would highly suggest that you look at all of the different items which are important in a tow vehicle. The engine size is only one consideration and the truck will probably be a better tow vehicle.
2012 Gerogetown 337XL
Tow Dolly
DW of 24 Years.
Hope to meet you on the trail.
ejw7213 is offline   Reply With Quote
Old 02-18-2014, 08:10 PM   #8
X2 on rockfordroo's comment. Not sure what the towing packages/options are with the new silverados. Definately verify the options with the tow chart. You will need a good W/D hitch with the tongue weight on a crew cab.
2013 Salem 30KQBSS TT
Equalizer 4pt Hitch system-12K
2016 Ram 1500 Crew Cab Sport 5.7 Hemi w/8 Speed
Great Laker is offline   Reply With Quote
Old 02-18-2014, 08:12 PM   #9
I have a Yukon with the 5.3 engine and 3.73 rear end and it pulls our 24' camper great! I would not feel unsafe with the 27' camper. With that being said, the truck in my signature is my preferred tow vehicle and not just because its diesel and a F250, although it does tow better. I love having the bed of my truck for firewood, bikes, generator, tripod and whatever other odds and ends may find their way in. In the Yukon, I can get wood and generator but even with a tarp and such it still gets a bit messy inside. Not to mention bugs....
99 F250 Super Cab Short Bed 7.3 Powerstroke
84 24' Yellowstone Camino (oldie)
Acableguy06 is offline   Reply With Quote
Old 02-22-2014, 10:02 AM   #10
I bought a Ford F150...never bought a Ford before but it is a supercrew 5.4 Triton V8. 2004. This should be ok right?
