Old 09-30-2015, 05:28 PM   #51
Originally Posted by earlbalentine View Post
I had a 2011 Chevy Corvette with 32 miles on it driving home from the dealer.
When I hit that 70-75 mph on the freeway it had that same vibration. After numerous trips to the dealer and even the regional service mgr ackknowledge there was a problem, it never got fixed. New tires and 3 sets of new wheels never corrected the problem. I suffered for 3 year and 16k miles until I sold it.
Thx for the info.
Drive shaft.
EdnKat is offline   Reply With Quote
Old 09-30-2015, 05:43 PM   #52
Busybeavers's Avatar
Originally Posted by SYE View Post
The difference in what you get gas mileage with the diesel vs the gas engine when towing will make of the difference in price
I purchased a '12 GMC Serra duramax new, it has 20,000 miles on it and coming back from PA (not towing) I got an over all average of 22.8 mpg, there were sections I check it and was getting upwards to 26.8 mpg. towing is normally 12-13. Love that truck! And not 1 warranty problem unlike the Ford 6.0 that I traded in - engine had 3 blown head gaskets, and always had injector problems. Stay away from Ford 6.0.
Busybeavers
2016 CC Silverback 29RE
2012 GMC 2500HD 4x4
Crew/6.5 Bed
Pullrite Superglide
Duramax/Allison
Busybeavers is offline   Reply With Quote
Old 09-30-2015, 06:24 PM   #53
Owned a Chevy 2500 gas and traded it in for two reasons. The gas mileage loaded or empty was awful... 6-8 mph towing and 10 to 12 empty. Got an F250 Diesel and now get 17-20 empty on trips and 14-15 towing. But more importantly, the difference in towing is night and day and much or stable in terms of suspension and braking.
magpi26 is offline   Reply With Quote
Old 09-30-2015, 06:37 PM   #54
Don't know much about GM or Ram, but I've got a Crusader 320 rlt that is similar in size and I pull it with a Ford F350 Super Duty, 6.8L V10 gasser. Does the towing job very well. Regardless of what you pick, don't expect much in the way of mileage.
rovinglion is offline   Reply With Quote
Old 09-30-2015, 06:38 PM   #55
Major's Avatar
I've had two different diesel vehicles and two different V-10 gassers all pulling campers in my 20+ years. While the V-10's did OK pulling they did not compare to the diesels, especially on hills or in the mountains. Mileage between the gassers and diesels isn't even in the same ballpark. If you can afford the diesel and will be pulling a lot, it is worth it.
Doug and Becky Ridgeway
2014 Blue Ridge 3600RS
2014 Ford F-350 CC 4X4 DRW 6.7 PSD
Troy, NC
Major is offline   Reply With Quote
Old 09-30-2015, 06:47 PM   #56
Georgia Frog Rally 2018
aceinspp's Avatar
Well I tried to buy a new 2015 RAM 2500 Diesel the cost was just out of reach for me.
If I choose to down size to a Chevy 2500 big V8 gas or a Ram 2500 big V8 gas, will wither of these be capable of towing my 10,000lb dry/12000lb GVW?
The trailer will be a 5th wheel.
The Diesel for around $50k but I can get the big V8 for $44K. Help!
I think this was the question. Don't see where diesels comes into play here. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 09-30-2015, 07:02 PM   #57
Chevy 2500 Gas Eng or RAM 2500 Gas
Originally Posted by aceinspp View Post
But that is not was the title of the thread is. Stick to the question. If he wanted to know he would have asked. Kind of like other forums I've been on gets derailed cause someone always thinks things are better. One person starts out asking question about electric locos and the next thing you got folks saying how much better battery operations. Later RJD
Actually in post #16 he talks about negotiating again for the diesel.
2014 XLR27HFS
2006 Ford F450 Diesel Dually
2015 Harley Freewheeler Trike (Tara)
2004 Harley Road King Custom (Gemma)
breezyhillfarm is offline   Reply With Quote
Old 09-30-2015, 09:30 PM   #58
Regarding your truck decision
I have a 2015 Silverado 1500 Max trailer pack truck and pulled a 12000 lb rated toy hauler (actual trailer weight 11000lbs.) You mentioned limited trailer pulling
which is pretty much what I do, did one trip of about 1000 miles round and plenty under 200 miles
5.3 pulled it well fuel economy towing around 8, fuel economy solo higher than 18/23 works well for my needs smoother riding also
tonyb1725 is offline   Reply With Quote
Old 09-30-2015, 09:53 PM   #59
lckeehne's Avatar
I have had 454 GMC dually and Chev gas
I now have diesel. The power is crazy better than gas. My gas mileage is 2 1/2 miles per gallon better with diesel.
That's saves lots of money on our budget. The up charge was $7,400 getting diesel. In my humble option well worth it especially when considering the longevity of Diesel engines.
lckeehne is offline   Reply With Quote
Old 09-30-2015, 10:18 PM   #60
drittal's Avatar
Can't compare an older rat and it's drrivetrain to the modern gas plants any more than you can compare a 12V cummins to a 6.7.
drittal is offline   Reply With Quote
500, gas
