Old 08-16-2012, 03:11 PM   #11
Herk7769's Avatar
Originally Posted by Len & Cheri View Post
10,000 is his GVWR.
Why would it have the same GVWR as mine (exactly)?
10,000 is for the new frame.
HAM CALLSIGN - KC3FFW
Old 08-16-2012, 03:29 PM   #12
I was just quoting his 10,000 lbs he posted and then Dave_Monica said he had the wrong figures. Then later in his post Dave_Monica talked about his 10,000 GVWR. My GVWR is also 10,000 just like yours (exactly). Pretty clear now right
Len & Cheri is offline   Reply With Quote
Old 08-16-2012, 03:49 PM   #13
Herk7769's Avatar
Originally Posted by UT Cardinal View Post
I can see where you are getting 16K-17K from the Chevy owners manual; however, if you go to the Duramax owners manual, it will give you the higher weight limits -max trailer weight of 13,900 lbs and GCWR of 22,000 lbs.
The label on the door states:
GVWR 9200 lbs
GAWR FRT 4860 lbs
GAWR RR 6084 lbs
I am not sure how much the truck weighs?
I should mention the truck is a 4x4, crew cab, short box.
He clearly stated it was 9200 pounds just like mine.
The trailer max he quoted was the Travel Trailer max with WD hitch.
The GCWR is correct also. Missing is the 15,200 pound 5th wheel max.
Like Dave and I said, a 2500HD will payload out well before he hits his GCWR or max trailer weight.
