Old 09-01-2016, 01:00 PM   #91
Originally Posted by bridgekev View Post
For those facing the same issue and following the thread, I took the trailer to a Forest River dealer to have the wiring inspected. They didn't find any problems. They started at the connector and worked their way back, including the trailer brake wiring. The labor wasn't covered by the warranty because they didn't find any problems.
Still need to try with another trailer. I still think it is with the trailer, not the truck.
If not camping, I am Sailing
JohnVtx is online now   Reply With Quote
Old 09-01-2016, 01:38 PM   #92
I'm not going to get snarky as you are entitled to your opinion, but if you review the thread, or try a google search, you'll see that more than a few Chevy owners are having the same issue with a variety of trailers. In a sense I agree that it's the trailer, in that pulling it exposes the truck malfunction.
2016 Forest River Grey Wolf 26DBH
2013 F-150 w/ 3.5L Ecoboost
bridgekev is offline   Reply With Quote
Old 09-01-2016, 02:10 PM   #93
Did you ever try pulling the trailer (safely) without the electrical connected?
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 09-01-2016, 02:11 PM   #94
If you don't try another trailer you will never convince your dealer, it is not your truck. But you don't have to listen to anyone. Especially me.
Old 09-01-2016, 02:24 PM   #95
Had similar problem with my 2015. Found that an after market plug mounted on sidewall of truck was causing the problem. Removed it and used the plug in the bumper which was original equipment. Everything now works. Purchased a new high quality plug for sidewall mount and it works as well. Might give that a try. Won't cost you anything but a few minutes of your time to test.
Good luck.
TXCPL is offline   Reply With Quote
Old 09-01-2016, 02:29 PM   #96
Intermittent problems are always the toughest to solve. Keep us informed of your progress, please.
2011 Traverse LT, 3.6L, FWD
Old 09-01-2016, 02:58 PM   #97
nomad297's Avatar
It is definitely due to something made in China!
Bruce
Old 09-02-2016, 07:08 AM   #98
I am on a trip right now with my 2016 2500. I have now twice gotten the trailer brake warning and service stabilitrac. The dealer has replaced the truck trailer plug due to water in it. I have temporary "solved" the issue by disconnecting the trailer plug and pulling the emergency brake on the trailer a couple of times. Reconnect and drive 20 yards, and everything returns to normal.
When I get home, the trailer goes to the dealer.
Mark
Wileykid is offline   Reply With Quote
Old 09-02-2016, 08:40 AM   #99
Mark,
What kind of trailer are you pulling?
Old 09-02-2016, 09:16 AM   #100
2016 stealth 2515.
I am having the dealer pull the codes off the truck today. The codes that only the dealer can get. Just to make sure.
Problem with these new trucks is any minor electric glitch and they freak out, and shut down.
Thing is I am in Wisconsin, on my way home to California. So this will keep me awake at least. Can't have a dull vacation.
Mark
