Old 08-16-2016, 07:26 AM   #51
It was the the first plug connector from the left rear wheel sensor, it had to be cut and and installed some new weather proof connectors. To bad they all can't be easy fixes! Hopefully the issue gets sorted out on these other trucks.
Ramrod79 is offline   Reply With Quote
Old 08-17-2016, 07:05 AM   #52
I've had 4 GM HD trucks over the years with zero issues like this. My last 2 were a 14 and now my 16. I've also had 2 HD Dodges, and 2 HD Fords. Neve had any issues with any of them with electronics, brake controllers, ect. Just the usual EGR with my Ford 6.0 and shitty seats in my Dodges. Lol. Hope they fix the issue. It is warrantied which is a good thing but your original dealer sounds like a bunch of yahoos so find a better dealer. I like my GMC dealer locally.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 10 so far
DocGTO is offline   Reply With Quote
Old 08-17-2016, 10:13 AM   #53
I've been to three dealerships. The warranty isn't doing me any good because they can't fix it. Chevy customer service told me they aren't taking any action. Buyer beware.
2016 Forest River Grey Wolf 26DBH
2013 F-150 w/ 3.5L Ecoboost
bridgekev is offline   Reply With Quote
Old 08-17-2016, 10:39 AM   #54
5 hole's Avatar
Originally Posted by doc73 View Post
My 2010 1500 had this similar issue and would go into limp mode. It was moisture in the connectors of the ABS or speed sensors.
I notice you had the original Poster, Bridge have the EXACT same trailer!! Only 2 years apart, coincidence??
Stefan
2014 - Sabre 36 QBOK
Nights camped 2014 - 38
Nights camped 2015 - 46
Nights camped 2016 - 43
Nights camped 2017 - 2
5 hole is offline   Reply With Quote
Old 08-17-2016, 10:41 AM   #55
Bridgekev -
I understand your frustration. Please don't blame your truck for something that may not be it's fault. I just went back through the entire thread. I have to ask you agsin, have you or the dealer try towing a different trailer with this truck? You really need to know which unit is causing it. As an arbitrator, I'd be asking you how you could prove its the truck and not the trailer if you want it lemon lawed.
Just trying to help,,,,,
If I missed it in there, forgive me.
Springerdad is offline   Reply With Quote
Old 08-17-2016, 10:48 AM   #56
I know you said you didnt want to trouble shoot and felt that you didnt have to but have you tried hooking up to a different trailer yet? I know there were a couple people (myself included) recommending it. This will isolate the problem between the truck or trailer?
Since it only happens when towing you need to rule out if it is happening when you tow everything/anything or just your trailer.
2015 Forest River EVO 2850
2012 Dodge Ram 2500 6.7 Cummins
Yamaha 2k x 2 with parallel cable
EMS 30 PI portable w/ Edison plug
Nights Camped (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 08-17-2016, 11:45 AM   #57
Thanks Springer dad for the advice. I brought the trailer in with the truck twice at different dealers. I took the trailer with the truck to an RV service place to verify the hitch set up. I think it would help my case if I have documentation of the trailer wiring being inspected. It's a 2016 trailer under warranty and I have a couple cosmetic issues to get fixed. Might as well have them check wiring.
Old 08-17-2016, 11:55 AM   #58
Suicide Saints- The problems with hooking up another trailer are 1) I don't have another trailer and 2) It's an intermittent problem. It's happened after 200 miles, 800 miles, 1200 miles, etc. The last dealer test drove the truck with trailer for 90 miles, only to have the issue again after I took it a few hundred.
Old 08-17-2016, 12:06 PM   #59
You may want to do a search on The Diesel Place forum. Lots of good info there even if your model isn't a diesel. It's all about GMC.
lakejumper is offline   Reply With Quote
Old 08-17-2016, 12:06 PM   #60
Understandable, me personally I would still try everything I could, maybe borrow a friends trailer and tow it for a day, all it would cost is fuel and time, just a thought. Just trying to spit ball ideas, I hope you get it worked out, I know it is frustrating when your stuff doesn't work right, it drives me crazy.
