Old 11-07-2014, 09:43 PM   #11
muddyrode's Avatar
your milage will only change from .5 to 1.5 depending on how you drive but you will gain an extra 4000# tow rating with the 4:10's, i know guys with both a 4:10 in a 2015 and the 3:73 in a 2013 not much differance unless you are going to do a Lot!! of hiway driving without a trailer
i can get 19+ hiway with my Duramax and would never go back
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 11-07-2014, 09:48 PM   #12
davel1971's Avatar
I had a 09 GMC 2500 with a 6.0 and 3.73s and was getting about 7-8MPG towing 8000 lbs., about 13MPG not towing. Now towing 11,500 lbs with a Duramax and getting 12MPG, 20+ not towing.
David & Lynn
Old 11-07-2014, 10:08 PM   #13
WFD
I have a 2011 2500HD with the 6.0L and it has the 3.73....the 4.10 was pretty hard to find. I didn't really want the 4.10 so coming across the majority of used 2500's with 3,73 suited me just fine. Talked to a couple dealers and they were telling me they were pretty much just bringing them in with 4.10's on a factory order.
My main reason was due to the majority saying mileage would suffer with 4.10's when not towing, which would be about 80% of the mileage I do, so I didn't want to chance it and find out.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 11-07-2014, 10:26 PM   #14
Oklahoma Proud
MillerTime's Avatar
Originally Posted by Eltonnoland View Post
I've been looking at new and used Chevy 2500's and want a 6.0 gas. As I understand it, a 4.10 is the only rear end offered on a 6.0.
This is correct. (For the U.S. other countrys may get different options)
If you get a 6.0 in a 2500hd or 3500hd you can only get 4.10
If you get the 6.0 in a 1500hd or 2500 (no hd and no longer offered) than you could get 3.73
If you get the duramax in anything (except 4500 and 5500) from day one, from the '01 on, you can only get 3.73 gears.
5.3 has the 3.08 and 3.42 in the 1500 and you can get the 3.73 with the 6.2 in the tow max package (prior to the 6.2, it was the vortec max and had the 6.0.)
4, 5, or 6 speed trannys, this is how the gearing has been on the hd line up, unless someone had the gears changed (the 1500 non hd trucks have had several optional gear/package changes since the '99s came out.)
Any question on your ratio, send me you Vin and i can run it at work, or you can just find the gear option code in your glove box.
Seems like we went thru this about a year ago on here.
Old 11-08-2014, 01:31 PM   #15
Thanks for your reply. Has the 2500 HD ever been offered with the 3.73?
Eltonnoland is offline   Reply With Quote
Old 11-08-2014, 01:42 PM   #16
davel1971's Avatar
yes, my 09 GMC was
David & Lynn
Old 11-08-2014, 01:44 PM   #17
WFD
Like I mentioned in post #13....my 2011 has 3.73.
Old 11-08-2014, 02:02 PM   #18
Airmech
If your talking gas mileage, I've got an 01 GMC 3500 dually diesel and I'm getting upper teens lower twenties on the highway. That's an old big truck to get that kind of mileage and towing mileage is better than any gas.
Pilot- Aaron, Copilot- Erica and Licker- Lizzy and Abby
5ver- TBA
2001 GMC 3500 Dually
smittyams is offline   Reply With Quote
Old 11-08-2014, 02:34 PM   #19
Oklahoma Proud
MillerTime's Avatar
Sorry i must have missed a few years there.
The 01-07 were like i said and the past couple years were that way on online ordering. Maybe you could order different in person or for different regions??
Sorry about the confusion. Heres some common rpo codes that you can look for
Old 11-09-2014, 09:31 PM   #20
I have a '01 2500HD with a 4.10 and the vast majority of the older ones I shopped were that, although I did see a few 3.73. I don't think it really makes any more than a marginal difference in gas mileage but it does make a big difference on how much you can tow with it so make sure you do your homework. If you're thinking you'll save gas by jumping down to a 3.73 I wouldn't personally do it if you're planning on using it as a tow vehicle.
Backcountry is offline   Reply With Quote
