Old 08-15-2014, 12:36 PM   #11
Night Stone's Avatar
Originally Posted by f1100turbo View Post
Lol no ford fan here either.
It would be much better with the 373 gear for sure which u have.
What is that burbs towing specs?
TURBS
"SABRE OWNERS UNITED"
I believe they rated the 6.0 at 7200lbs with the 3.73 gears
98 Chevy Silverado C3500 crewcab, 454 cu in & 2013 Salem Cruise-Lite 181BHXL
FRF and FROG member
Days camped in 2012 (3), 2013 (3), 2014 (6)
Days camped in 2015, 0 Days so far (0)
This Space for Rent
Night Stone is offline   Reply With Quote
Old 08-15-2014, 12:48 PM   #12
AquaMan's Avatar
Ours is around 8600lbs with 6.2l, not sure of the CCC. Ours also came with all the towing features, brake controller etc, but no hitch.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 08-15-2014, 02:20 PM   #13
Ok I have found some specs based on a 06 Suburban 2500
GVWR 8600
Towing Capacity 7900
GCWR 13822
Payload is 2828
FRF and FROG member
This Space for Rent
Old 08-16-2014, 05:15 PM   #14
beerjay's Avatar
My 2009 Suburban is ok with the trailer I have for towing the Flagstaff. TT is 4400lb yellow sticker and 5100lb CAT scale weight.
Towing up grades 7-8% will put you at 3-4000 RPMs which is unnerving but not out of line. Wind loading is the bigger issue since the TT is a big front or side sail. Not likely a way to deal with that without a deflector.
I need the passenger capacity too, but load the TT with the gear since I'm close to the GAWR loaded. I get 8-12 MPG CDN average depending on grades with the 4.3L 3.42 axle.
I tow 5000km per year so I don't plan to upgrade till the new small diesels hit the market.
I added the aux transmission cooler which was not part of the HD towing package. Towing capacity for the 4x4 is 5400lb no cooler, 7900lb with cooler. My CCC is around 1600 lb per the GM build sheet and stickers in the door.
2009 Suburban LT 1500 - 4x4 - 3.42
2009 Flagstaff 23FBS Super Lite
Nights Camped in 2015 - 21
Nights Camped in 2014 - 29
Nights Camped in 2013 - 31
beerjay is offline   Reply With Quote
Old 08-25-2014, 07:52 PM   #15
I have a 2007 2500 LTZ Burban. It is a beast.
MikeRP is offline   Reply With Quote
