08-15-2014, 11:33 AM
Chevy Surburban
Has anyone towed with this SUV? What are the pros and cons? The reason is I would like to get this SUV, cause of it's number of passenger seating. The ideal drivetrain is a 6.0 with 3.73 gears. My current trailer is Salem Cruise lite 181BHXL with shipped dry weight of 4300 lbs. Add items and such to trailer it's probably tops 4600lbs.
Dave
98 Chevy Silverado C3500 crewcab, 454 cu in & 2013 Salem Cruise-Lite 181BHXL
FRF and FROG member
Days camped in 2012 (3), 2013 (3), 2014 (6) Days camped in 2015-18, 0 Days so far
Days camped in 2019, (8)
This Space for Rent
08-15-2014, 11:39 AM
Dave
Normal user added item is around 1000#
Don't think you can load up and go for 300#
Oh dear the list.
Clothes
Food
Beverages
Toiletries
Dishes cups silverware
Tools
Chairs
Blankets pillows
Pots pans
Coolers ice
Lanterns
Water in the fw tank
Etc etc
Lol if you can only carry 300# and camp comfortable then cheers to ya! [emoji482]
With that being said I pulled a 32' flagstaff ultralight with my suburban 5.3 323 gear for 5 years.
TURBS
"SABRE OWNERS UNITED"
08-15-2014, 11:43 AM
Oh dear the list.
Clothes
Food
Beverages
Toiletries
Tools
Chairs
Blankets pillows
Pots pans
Coolers ice
Lanterns
Etc etc
TURBS
How does it do on mountain grades of 6-8%?
FRF and FROG member
This Space for Rent
08-15-2014, 11:44 AM
I'm a flatlander! No mountains.
Hills maybe.
TURBS
08-15-2014, 11:50 AM
Keep in mind that 4300 dry weight is most likely even higher then that after the dealer gets it.
He adds.
Battery/ batteries.
Propane tanks full of propane.
Any add on items you requested.
Sometimes awnings , microwaves, and televisions are added at the dealer.
TURBS
08-15-2014, 11:51 AM
DW has a 2014 Yukon XL with the 6.2L and it's a beast. To give you an idea of MPG, my 3500 dually crewcab 4x4 is our economical vehicle!
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
08-15-2014, 11:52 AM
Do you know the GVWR of the trailer? That is the best to go by. As was stated. 1,000 lbs is not a crazy number for gear and stuff. My new pop up has a GVWR around 4,500lbs. I would suspect your quite a bit north of that.
That being said. I think as long as you have the tow package your good to go. I am looking at the Tahoe as a potential replacement for my Trailblazer. The suburban is quite a big bigger as you know.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
08-15-2014, 11:54 AM
Vin.
To further your post.
To op will most likely run out of ccc on the suburban before anything else.
Ccc "cargo carrying capacity"
Loaded hitch weight plus hitch , passengers and any gear stowed inside suburban.
TURBS
08-15-2014, 12:09 PM
Chevy Surburban
TURBS
Probably, but that is why I was thinking of the 6.0 with 3.73, the other option is a diesel Excursion
I am not much a Ford fan and neither is the DW
FRF and FROG member
This Space for Rent
08-15-2014, 12:10 PM
Probably, but that is why I was thinking of the 6.0 with 3.73, the other option is a diesel Excursion :0
Lol no ford fan here either.
It would be much better with the 373 gear for sure which u have.
What is that burbs towing specs?
TURBS
08-15-2014, 12:36 PM
TURBS
I believe they rated the 6.0 at 7200lbs with the 3.73 gears
FRF and FROG member
This Space for Rent
08-15-2014, 12:48 PM
Ours is around 8600lbs with 6.2l, not sure of the CCC. Ours also came with all the towing features, brake controller etc, but no hitch.
08-15-2014, 02:20 PM
Ok I have found some specs based on a 06 Suburban 2500
GVWR 8600
Towing Capacity 7900
GCWR 13822
Payload is 2828
FRF and FROG member
This Space for Rent
08-16-2014, 05:15 PM
My 2009 Suburban is ok with the trailer I have for towing the Flagstaff. TT is 4400lb yellow sticker and 5100lb CAT scale weight.
Towing up grades 7-8% will put you at 3-4000 RPMs which is unnerving but not out of line. Wind loading is the bigger issue since the TT is a big front or side sail. Not likely a way to deal with that without a deflector.
I need the passenger capacity too, but load the TT with the gear since I'm close to the GAWR loaded. I get 8-12 MPG CDN average depending on grades with the 4.3L 3.42 axle.
I tow 5000km per year so I don't plan to upgrade till the new small diesels hit the market.
I added the aux transmission cooler which was not part of the HD towing package. Towing capacity for the 4x4 is 5400lb no cooler, 7900lb with cooler. My CCC is around 1600 lb per the GM build sheet and stickers in the door.
2009 Suburban LT 1500 - 4x4 - 3.42
2009 Flagstaff 23FBS Super Lite
Nights Camped in 2015 - 21
Nights Camped in 2014 - 29
Nights Camped in 2013 - 31
08-25-2014, 07:52 PM
I have a 2007 2500 LTZ Burban. It is a beast.
