Old 08-05-2015, 01:43 PM   #11
AquaMan's Avatar
If you're worried about rpms, think about a boat. The 7.4L in my boat would run 5000+ for an hour or more if I was heading up lake, and I would do this all weekend long every weekend.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 08-05-2015, 02:30 PM   #12
Tonkatoy77's Avatar
A boat doesn't put as much load on the engine as a truck with a travel trailer.
2007 Chevy Duramax EFI Live and other supporting mods.
2015 Wildcat Maxx T26BHS
Nights camped 2015....23
Tonkatoy77 is offline   Reply With Quote
Old 08-07-2015, 08:41 AM   #13
AquaMan's Avatar
I'm going to have to disagree with that statement. A marine engine is under constant load, "generally" has 1 gear, and never coasts downhill.
Old 08-07-2015, 08:49 AM   #14
TURBS's Avatar
I have to disagree as well!
big and small black boat motors are highly sought after for there forged engine parts.
Unlike the automotive cast parts.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-07-2015, 08:52 AM   #15
Jim Schings's Avatar
?? Physics 101 It will put on the exact same "load" as any other engine given the same HP and throttle position. HP=(RPM x Torque)/5252.
It's not my opinion, It's the law.
Re: the desirability of marine engine parts: Nothing to do with marine vs. land. It is simply that most marine engines are often built to a higher displacement to HP ratio (customer demand). Thus, forged parts are often used. If you purchase a similar ratio street engine, you get the same forged parts....
Jim Schings is offline   Reply With Quote
Old 08-07-2015, 09:12 AM   #16
mud yapster's Avatar
6.7L diesel 1700 RPM at 65 mph and 2000 to 2100 up hill and a big hill 2400. LOL No gasser here it doesn't slow down for hills towing my 18K 5er.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 08-07-2015, 09:31 AM   #17
Tonkatoy77's Avatar
Chevy Truck RPM
you just proved my point! A marine engine has a constant load. Why do you think a B series Cummins lasts 2-3 times longer in a boat with a higher horsepower rating than in a Dodge pickup? Same idea with a gen set. Once you get it going, you maintain that speed for long periods of time. And when you are at 5000 RPM's, you are not at 100% load. When you are in a pickup you are at 100% load, then back down, then on the next hill your back at 100%.
Old 08-07-2015, 10:33 AM   #18
Based on, hours, miles, RPM? Need a metric to make that point.
With a genset, you are arguably true since it is rated at some peak HP and you seldom use but a small percentage of that. That is NOT the case with a marine engine.
Can you clarify? What are you calling "load"? HP, Torque, RPM? Need a metric again.
Doubtful. Again what is "load"? Again see HP=(RPM x Torque)/5252 and explain your metric. "LOAD" is not HP, torque, or speed (RPM). It is a measure of mass and means nothing in the conversation..
Are you saying he is not using full HP, full TORQUE, or RPM. And how do either relate to longevity in you mind...
Old 08-07-2015, 01:15 PM   #19
Tonkatoy77's Avatar
Chevy Truck RPM
I guess I am going to have to go back to school then, because I have always been taught that engine load is based on air flow vs. fuel used. I have never used the equation you are using to determine engine load. And neither does combustion engine manufacturers. Based on what you are saying if I was coming down a 7% grade with my pickup and TT at 2500 RPM's my engine would still be under load. The way I was taught there would be no load because there would be no fuel.
You asked what I am calling load. It would be energy used.
Old 08-07-2015, 01:21 PM   #20
Tonkatoy77's Avatar
Chevy Truck RPM
I am basing my difference between automotive and marine applications with engine hours.
truck
