Originally Posted by Tonkatoy77
I have always been taught that engine load is based on air flow vs. fuel used.
Air Flow vs fuel used (in mass) is simply the air fuel ratio. It varies from 14.7 to 1 to 12 to 1. (In a gas engine.) It has nothing to do with load. In a diesel, this is not typically even applicable but the range is much wider and much more complex.
I have never used the equation you are using to determine engine load. And neither does combustion engine manufacturers.
Really?
It is one of the most common of all formulae used in physics and especially in reciprocating engines of all kinds. It is this formula: 33,000
ft-lbf/min adjusted for rotating motion. Guy named James Watt came up with it...
Based on what you are saying if I was coming down a 7% grade with my pickup and TT at 2500 RPM's my engine would still be under load. The way I was taught there would be no load because there would be no fuel.
??? In either a diesel or gas engine, there is no HP being developed by the engine when going down a hill. Both engines shut the fuel off when decelerating. Look at the formula again. Torque would = 0 going down a hill. (actually it would be minus....)
You asked what I am calling load. It would be energy used.
Then the energy used would be in HP, or BTU, or KWH. "Load" could loosely be used when discussing torque, (as in foot lbs. of force)
