Old 06-23-2016, 11:00 AM   #1
Choosing IBC Settings on '16 RAM
This is my first fiver setup ever. I have a 2016 Ram Megacab 2500 with the Cummins, pulling a 2016 Coachmen Chaparral 360IBL. Trailer is 14k max wet
I have no data (that I could locate in any manual) to help me select the brake controller settings. Light Electric? Heavy Electric? Light Electric over Hydraulic? Heavy Electric over Hyrdaulic? Leave default gain values? What setting should I start with, considering my rig, and why?
jorn_k is offline   Reply With Quote
Old 06-23-2016, 11:13 AM   #2
W5CI's Avatar
IMHO you should use Heavy Electric, unless your 5er came with disc brakes. At 14K you are not Light electric.
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 44
W5CI is offline   Reply With Quote
Old 06-23-2016, 12:31 PM   #3
Lots of trailer for that 2500. Considering you are way overweight, I would select Heavy Electric with the gain maxed out.
I assumed your trailer does not have hydraulic brakes.
325BH is offline   Reply With Quote
Old 06-23-2016, 01:07 PM   #4
shorthorn's Avatar
Heavy electric, I run gain around 6.5-7 on my dually. Use the exhaust brake too! Lotta weight for a 3/4 ton... our 360IBL is why I sold the 2500 and got this dually.
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
shorthorn is offline   Reply With Quote
Old 06-23-2016, 01:13 PM   #5
Definety heavy electric setting and start the gain around 5 ish and play with it form there.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 06-23-2016, 10:32 PM   #6
Thanks, folks, for your response to my question.
Old 06-24-2016, 10:41 AM   #7
Kenny kustom's Avatar
Keep in mind, the voltage is reduced, under 30mph
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 06-24-2016, 10:43 AM   #8
Originally Posted by 325BH View Post
Lots of trailer for that 2500. Considering you are way overweight...
What data are you basing that upon? I tried to buy more truck than I needed.
Old 06-24-2016, 02:27 PM   #9
jtatum65's Avatar
I have a '16 2500 Big Horn and have it set to heavy electric. The gain is set to 5.5 and I have no problems, but then again I have a lighter FW around 10000lbs.
You want to set the gain so that when you apply brakes that the trailer starts to break before the truck does. You want the trailer to assist in braking by holding back a little and not rely in the truck holding the trailer back. Something I learned from 12yrs of OTR trucking.
Jim & Evelyn Tatum
2018 Shasta Phoenix 336RL FW
2016 Dodge Ram 2500 Big Horn 6.4L Hemi 4x4
Nights Camped 2019 = 3
Nights Camped 2018 = 28
Nights Camped 2017 = 27
jtatum65 is offline   Reply With Quote
Old 06-24-2016, 02:33 PM   #10
jeepman71's Avatar
I run my 2015 3500 at heavy electric and 6 or 6.5 gain and use the exhaust brake and tow mode. Works well for mine at 12K.
Jim, Julie and Rags the boss.
2015 Dodge CTD 3500 Bighorn pulling 2014 Wildcat 317RL. Life is good when spent with family and friends.
jeepman71 is offline   Reply With Quote
