Old 07-28-2014, 09:53 AM   #1
Chucking with my Rockwood 8289
I am using the Sidewinder feature on my Rockwood 8289 ,towing with my Ford F250. I am experiencing chucking and being new to 5th wheel towing and being in the UK where advice is scarce ,can anyone give me advice? I have found online that several people have found the Mor/Ryde pin box greatly helps.But can I fit this with the Sidewinder hitch?
My truck hitch is a Reese R16.
Any advice much appreciated.
Rodders is offline   Reply With Quote
Old 07-28-2014, 09:57 AM   #2
Doubtful, but I really don't know. Shocks on the trailer stopped it on my Flagstaff.
Old 07-28-2014, 11:49 AM   #3
BamaBob's Avatar
Like OC, I would check your shocks - how old is your 5th Wheel?
Chucking is typically caused by worn shocks and/or low pin weight.
Weight distribution is pretty important; best case is heavier in the front of the 5er. What you do NOT want is to have all your heavy stuff in the back (use your basement, that's what it is there for
On a totally different Vein You are a towing GOD!
I was stationed in the UK for over 4 years when I was in the Air Force and no way would I ever had the guts to yank a 8289 with a F250 down some of THOSE back roads
For those un-informed as to what I mean... Here is a photo of the A38 Country Lane 2 some Brits consider this a wide road
I suspect you are strictly a Motorway driver with that rig
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 07-28-2014, 12:12 PM   #4
I put shocks on my TRAILER to stop the chucking. Truck shocks were good even before and I had chucking.
Old 07-28-2014, 12:44 PM   #5
Witch Doctor's Avatar
I am using the Sidewinder feature on my Rockwood 8289 ,towing with my Ford F250. I am expeiencing chucking and being new to 5th wheel towing and being in the UK where advice is scarce ,cn anyone give me advice? I have found online that several people have found the Mor/Ryde pin box greatly helps.But can I fit this with the Sidewinder hitch?
You CAN NOT install a Mor ride. The reason is that the Revelation is framed in a 10" space it will not fit. Your unit pin box and trailer was designed to fit that hitch alone. If you wanted a new hitch with the shocks that would work. You can PM Rodeo George he was going to do the same thing. You would have to change the framing to use that. This has been discussed in length. I still do think that will stop the chucking. You really can't add that much weight to change the distributions in my opinion no matter what anyone says. You can only add a total of like 1350 lbs. Now count in the propane and battery and water that you carry. You can get to gross weight and it still will not stop. The revolution is framed in so you can not add a 14" wide pin box or what ever the dimensions are.
Name:	Factory Tour 001.jpg
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 07-28-2014, 01:00 PM   #6
B and B's Avatar
I had chucking when I first had the 8289 on my F150. LT tires which I assume are on the F250 already and weight. I put some weight over the pin. Between clothes, ladder under the bed and various other things in the basement (100 lbs of tools etc) it stopped.
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 07-28-2014, 01:14 PM   #7
There is noway in IMO that you can stop all chucking it is the nature of the beast. Drive down I-95 in SC. and tell me that. Mine will chuck at stops and acceleration. And going down one of Americas great roads. Concrete is the worst. What is your pin weight?
Coachmen M/H
Concord
2018 / 300 DSC
Old 07-28-2014, 03:00 PM   #8
Thanks to everyone for your advices and help. Not sure what my noseweight is- how do I measure it? Excuse my naivety but I'm new to all this Only been out a couple of times but off to France in 2 weeks- and yes done those "narrow" off motorway roads- but motorways are easier!! I work on the principal, anywhere a HGV truck can go, so can I.
Thanks again
Old 07-28-2014, 03:27 PM   #9
Thanks again
For me I would send a PM to Dave_monica, To me he is The best person on the forum. He will get back to you. He helped me out the most. Others here will help and are very Knowledgeable. But he breaks it down in easy terms, nothing ment against other members but to me he is the best. That is just my opinion and no insults intended...... Hay it took me 3x's on the scales before I got to mine which is 1640 lbs. He was very good with me.
Coachmen M/H
Concord
2018 / 300 DSC
Old 07-28-2014, 04:48 PM   #10
PhoneDude 8289's Avatar
When we first took delivery on the 8289 we had some pretty serious chucking. After taking a good look at things the RV was sitting a bit nose down when hooked to the truck on a level surface. I raised the hitch in the truck 1", didn't take out all the chucking but it sure got rid of most of it. Pretty comfortable ride now for the most part. Also slowing down on really rough roads helps.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
rockwood
