Old 10-13-2014, 11:02 AM   #11
TURBS's Avatar
So just about 200 left in payload.
Give or take?
Turbs
Old 10-13-2014, 11:05 AM   #12
Stormrider151's Avatar
I'm no math expert but I'm figuring around 500lbs.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 10-13-2014, 11:50 AM   #13
Looks like I'm closer on the truck than I thought but still under. A little over 200 May be closer to correct. GCVWR is 17100 and by my math would put me under max by 1950 lbs. if I'm not toady off base.
Old 10-13-2014, 12:01 PM   #14
TURBS's Avatar
Yep I'm off.
1708 payload
Minus
700 tongue
150 lbs passenger
100 lbs wd hitch
Around 800 minus anything else in bed.
Turbs
Old 10-13-2014, 12:25 PM   #15
Tell ya what I'll split the difference with you and say 400 lbs. gas tanks and battery will eat up a good bit. So to be safe, 400lbs. My figures on trailer are high estimates. I'll know for sure after I get everything on the scales. Thanks for your help.
Old 10-13-2014, 12:53 PM   #16
I would put my money into the best integrated sway control hitch you can afford, rather than a new receiver.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 10-13-2014, 01:11 PM   #17
That's a very real possibility. I brought it home with a single friction sway control that wasn't tightened properly (should have checked myself) and did get some sway. Not too bad. I'm adding a second bar on the other side to see how it does but I'm really thinking a better set up. I also have airlift ultimate 5000 bags to install to stiffen the ride a bit.
