Old 06-08-2019, 09:05 AM   #1
class IV and class V receivers
I sold my Nissan Frontier TV and have a deposit to purchase a '18 Ram 2500 CTD.
The online owners manual for the Ram shows the 2500 comes with a class V hitch.
Correct me if I am wrong, but I assume the class IV shank for my Equalizer WDH will not fit in the class V receiver on the Ram.
Is there an adapter to make a IV fit in a V? And if so, is it recommended to use an adapter?
Or should I bite the bullet and buy a shank designed for the V receiver?
The Ram owners manual also "suggests" using a WDH when the GVWR of the trailer exceeds 5000lbs. I might be able to just use a WCH.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 06-08-2019, 09:14 AM   #2
Moparman1230's Avatar
The Ram will come with an adapter sleeve, usually found under the rear seat. I didn’t like the “slop” using an adapter creates (and I needed a bigger drop), so I went ahead and bought a bigger shank.
The adapter works just fine.
"Do, or do not, there is no try." - Yoda
2017 Cherokee 294BH
2015 Ram 2500 4x4 6.4L V8 Crew Cab
Moparman1230 is offline   Reply With Quote
Old 06-08-2019, 09:15 AM   #3
DieselDrax's Avatar
You can use something like this...
https://www.etrailer.com/Hitch-Adapt...ese/58102.html
But you may run into slop issues. If you want to do it right then I would get a 2.5” shank, but the adapter is cheap enough and you could use it with other 2” hitch accessories as well.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
DieselDrax is online now   Reply With Quote
Old 06-08-2019, 09:47 AM   #4
Failure is my business
2Evil4U's Avatar
You'll most likely need to get a longer drop shank anyway so when you do, upsize to the 2.5".
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 16 Flagstaff 832IKBS, 14 RAM 1500 4x4 Hemi 3.92 Bilstein 5100's Derale oil cooler, 97 F150 4x4 5.4L 278,000 miles, 80 Firebird Esprit Aussie Burnout Car https://youtu.be/v06VjII7HmE, 78 Harley Davidson FX 79,000 miles dad bought new, 71 El Camino ZZ3 TH400 12-Bolt, 37 Ford 3 window 502 Chevy dad built
Days Camped: 2016: 43, 2017: 83, 2018: 44, 2019: 78
2Evil4U is offline   Reply With Quote
Old 06-08-2019, 01:17 PM   #5
Your new truck will come with a Sleeve
Both my 2500 and 3500 came with a new sleeve (it's usually stored under the back seat on a crewcut). Differing opinion on the use of these, but I tow a 10K camper and it stays pretty tight, no slop. I have no plans of upgrading to a larger shank.
Ron and Kathy
2019 Cougar 369BHS 5'VR
2018 Cherokee Limited 304 BH (Traded)
Joyfully Towed with a 2018 RAM 3500 6.7 G56
ronheater70 is offline   Reply With Quote
Old 06-08-2019, 02:20 PM   #6
Thanks all, good to know, it looks like I may have to buy another shank anyway since the drop will be much more than it was on the Frontier.
Old 06-09-2019, 10:19 AM   #7
Just be careful. That sucker is HEAVY!!
2017 Cherokee 294BH
Old 06-09-2019, 05:50 PM   #8
I know, my Equalizer WDH is 100 lbs all by itself.
