Old 06-13-2016, 07:16 AM   #1
Charles.maine's Avatar
Cold PSI raises fast when driving
So I have read over and over and over that you set the cold psi to the max. I have Goodyear G614s with max PSI of 80. After about an hour or so of driving the temps are about 10-15 degrees above the outside air temp. My concern is the PSI shoots up to 105-115. Is this something to worry about?
2015 Chevrolet Silverado 2500HD 4x4 Z71 Duramax/Allison Combo Pull Rite, ISR Series Superglide 16K, LoadLifter 5000 Ultimate W/ WirelessOne
Current RV: 2016 Palomino Columbus 381FL Fifth Wheel
Lippert Flex Air Pin Box, LT235-85-16 GY G614
Nights Camped 2013 - 6 • 2014 - 7 • 2015 - 12 • 2016 - 29 • 2017 - 16 (17 more planned!!)
Charles.maine is offline   Reply With Quote
Old 06-13-2016, 08:03 AM   #2
I've been wondering about this also.
2012 Windjammer 3001W
2016 Sunset Trail Super Lite 250RB-For Sale
2015.5 Chevrolet Silverado 2500HD LTZ crew cab Z71 4x4
KingFisher is offline   Reply With Quote
Old 06-13-2016, 08:10 AM   #3
Tfort's Avatar
The pressure should not climb that much. 5-10 psi max should be about all you should see.
2000 F250 CC 4x4 7.3L diesel
15 Salem Hemisphere Lite356QB
Tfort is offline   Reply With Quote
Old 06-13-2016, 08:15 AM   #4
SeaDog's Avatar
When the tire mfg sets the cold pressure they understand that the pressure will climb and the max cold pressure accounts for this. Your 20* temp climb does not seem to be normal there may be other factors involved. Speed, weight, alignment etc.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-13-2016, 08:33 AM   #5
clr
This may be a question for wtire a real tire expert. But I know when I set up my tire pressure monitoring system they said to set the high pressure alarm point at 20% above the normal cold tire set pressure. So if you set your tire to 80 PSI cold that would be 96 degrees F for the high pressure alarm point. So your increase to 105-120 PSI would set off the high pressure alarm. Sorry but I do not have a fix for you here.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 06-13-2016, 08:33 AM   #6
Jim34RL's Avatar
First off do you have TPMS on the trailer tires?
If so how accurate are the sensors; IE what is the tolerance range on them?
What is your background for determining that the tire pressure is too high when the tire has heated up do to rolling resistance!
Have you weighed the trailer and the individual tire to determine the weights to see if one tire is overloaded or the trailer?
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 06-13-2016, 08:36 AM   #7
Commercial Member
I agree that a temp increase of only 10 to 15F should not result in pressure increase of 30 to 45 psi. Something is wrong.
What brand TPMS?
Have you confirmed TPMS pressure against a known accurate digital hand gauge?
What are your measured tire loads?
What speeds were involved?
I only see about 8 - 10 psi with 10 to 15F at 63 mph. Of course I have at least 20% margin on load.
.Write a blog on RV tire application RV Tire Safety. 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Perry, GA and Minot ND in 2019
Tireman9 is offline   Reply With Quote
Old 06-13-2016, 08:45 AM   #8
Isnt the max pressure in the G614, 110 psi? For the size of your fiver, 80 psi may be way to low which would cause over heating which results in pressures rising disproportionately. If you start out with 110 psi, the tire will run cooler.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 06-13-2016, 08:52 AM   #9
I will double check the information when I get home and report back.
Old 06-13-2016, 09:01 AM   #10
Flybob's Avatar
Per Goodyear site.
Size
LT235/85R16 Capacity 3,750 LBS @ 110 PSI
Ply Rating 14
Service Description 126/123 L
Diameter 30.7" Width 9.5"
Tread Depth 12/32
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
