11-13-2016, 02:30 PM
combined weight
So vehicle GVWR is 6000lbs. with tow rating of 3600lbs. This means that both vehicles on scales can weigh 9600lbs. max right?
11-13-2016, 02:44 PM
You'll have to find the manufacturer GCWR. You're limited by the max vehicle weight, max towing weight or max combined weight, whichever is highest.
BIRDS AREN’T REAL
11-13-2016, 05:06 PM
Is 9600lbs your tow vehicle's GCWR? (Not GVWR)
11-13-2016, 05:25 PM
Umm, I think you are limited by whichever is LOWEST. Also in the list is cargo carrying capacity (GVWR-actual weight). Your tongue weight is part of the cargo limit and will generally be the lowest of the limits.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
11-13-2016, 06:35 PM
Duuuuh....good catch. It is lowest. Once you reach any one of the three limits the other two are no longer a factor.
BIRDS AREN’T REAL
11-14-2016, 10:01 AM
No, that is not correct. The gross combined weight rating is the base curb weight of the truck plus the tow rating and that includes a 150 lb. driver. In other words if you need to subtract the vehicle's maximum payload (sticker number) from your 9600 number in your example above.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
11-14-2016, 12:01 PM
Probably, the best thing to do is look up the towing guide for your vehicle. Should be easily found thru a web search.
Al
11-15-2016, 12:15 AM
Blog: RVroadtripper.com
I've found that the tow vehicles Payload and Carry Capcity may not be accurate if there are many after mfg addons like wheel changes, step bars, hitch, aitbags, etc. And its further clouded by passenger weight, fuel weight, and "our stuff". But the sticker number that is most relevant is the GVWR.
Load up the Tow Vehicle with family and stuff and head over to a CAT scale. Fill up with fuel and drive across the scales. Subtract your total vehicle weight on the CAT weigh ticket from the GVWR. The answer is your remaining Payload and/or Cargo Carry Capacity. For a fifth wheel, this is your limit for Pinweight, for a Travel Trailer, this is your limit for hitch weight (unless the sticker on the hitch itself has a lower max).
The owners manual list the Max Tow Capacity but my experience has been that pin or hitch weight limits will reach max way before tow max or trailer weight.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
11-16-2016, 07:04 AM
gcvw 8750, loaded up went to scales, 8620 total so about 150 under
11-16-2016, 07:20 AM
It would help if you list the TV & TT models.
BIRDS AREN’T REAL
11-16-2016, 09:42 PM
town and country and spree escape model 200
11-17-2016, 12:55 AM
Since the Spree isn't a FR product, what kind of trailer is it, popup, A-frame, hybrid or TT?
11-17-2016, 12:57 AM
Was that with passengers?
11-17-2016, 02:16 AM
You will not be able to pull a tt with a minivan. You are limited to pop ups with a minivan. The frontal wall surface area of a tt or even a HTT is too much for the town and country, even if you could find one with a light enough tongue weight. TT's act like a giant sail behind you and the minivan just doesn't have the weight or the wheelbase to combat that sail when the wind catches it.
kz Spree escape
2014 Sabre 34REQS-6
11-17-2016, 06:49 AM
Minivans have a frontal area limit.
Any full size TT will exceed that limit.
It's in your T&C's owners manual.
