Old 06-19-2012, 07:45 PM   #31
TURBS's Avatar
Originally Posted by onetonford
After looking up bearing parts for a 2001, 7.3 diesel 3/4 and my 1 ton bearing part numbers are totally different leading me to believe there is a difference..
Actual axle shaft diameter. Same housing
Old 06-19-2012, 07:47 PM   #32
TURBS's Avatar
Originally Posted by herk7769
I was not going to get pulled into this, but for the record I would love to hear from someone who works the parts counter at a Ford, Dodge, or Chevy Dealership.
I do know there is a BIG difference between my 2008 2500HD and the 3500HD. While the engine, trans, and rear end ratio are the same (thus the tow rating is the same), the frame is completely different.
My 2500HD has a C frame and the 3500HD has a box frame which results in the very different GVWRs.
Pulled you in hook line and sinker...... again!
Old 06-19-2012, 07:59 PM   #33
Herk7769's Avatar
I just checked some random parts off my GMC 2500HD and compared them to the 3500HD.
Front hubs:
2500 - Timken TMSP580312
3500 - Timken TMSP580313
result - Front axle - different
Rear Axle
Brake Rotor
2500 - 1JA097011
3500 - 1JA097031
rear bearings
2500 - Timken Set38
3500 & 4500 - Timken NP145100
result - Rear axle different
Failed the "load of hooie" check.
HAM CALLSIGN - KC3FFW
Old 06-19-2012, 08:17 PM   #34
onetonford's Avatar
Along time ago I had a 1977 Ford Heavy Duty Half and a Friend had a 1977 Ford F250 Camper Special while his had the floating rear axels and Eight Bolt pattern and mine had the 5 on 5 Bolt pattern the Gvwr on his was 6100 lbs and my 1/2 was 6050 we also checked frame size and mine was alot heaver approx 10" c-rail to his 5" C-rail I think it still has to do with the way the put these trucks together from the Factory.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 06-19-2012, 08:25 PM   #35
transamz9's Avatar
According to my NAPA pro link:
2008 GMC Sierra 2500 HD with 10.5" ring gear in rear axle:
Differential Seal & Bearing Kit - Rear Axle
Product Line: NAPA Bearings
Comments: w/ 10.50" Ring Gear;Include Bearing Kit Plus Ring Gear Bolts /Pinion shims/Carrier Shims
Per Car Qty.: 1
Select To Compare BRG SDK325BMK
Same truck with 11.5 ring gear:
Comments: w/ 11.50" Ring Gear;Include Bearing Kit Plus Ring Gear Bolts /Pinion shims/Carrier Shims
Per Car Qty.: 1
Select To Compare BRG SDK327MK
2008 GMC 3500 HD with 10.5" ring gear:
Per Car Qty.: 1
Per Car Qty.: 1
Now the 2500 did come with a 9.5" gear also and the 3500 didn't so if you have the 9.5" gear then yes that is different.
If your truck has the 10.5 or 11.5 then it is the exact same gears, bearings,and seals. I'm not sure if Gm made a SRW 3500 or not because the Napa parts is not listing the two different options on the bearing and seal kit.
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
transamz9 is offline   Reply With Quote
Old 06-19-2012, 08:34 PM   #36
transamz9's Avatar
2008 GMC Sierra 2500HD rear rotor:
Brake Rotor Only - Rear - Premium
Product Line: NAPA Brakes Rotors
Per Car Qty.: 2
Select To Compare NB 4886828
2008 GMC Sierra 3500HD SRW rear rotor:
Comments: w/ Single Rear Wheels
Per Car Qty.: 2
Same rotors two different GVW's
The only difference I can find is the springs.
2006 EZ GO 6" lift
Old 06-19-2012, 08:38 PM   #37
ironj's Avatar
Here is the 'final' word i got straight from ford. They didnt confirm or deny any speculation i had, but here is their 'answer'...
Basically they said ' here is the info you need' and sent us this to decipher
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 06-19-2012, 08:39 PM   #38
Herk7769's Avatar
Gary,
I am not sure what all that means. I am no motorhead for sure.
However, there seems to be significant differences between the 3500 SRW and the 2500 SRW (the 3500 Dualie is even more different).
A lot of figuring goes into the GVWR of a truck and the least common denominator sets the bar. I believe it is the frame and brake drum /rotor size in the 2008 2500 vs 3500, but there could be others.
Old 06-19-2012, 08:44 PM   #39
transamz9's Avatar
Originally Posted by herk7769 View Post
Gary,
This is the NAPA part # for the rear rotors on your truck and also the 3500HD SRW.(NB 4886828) Same rotors. I just looked up the front ball joints , upper and lower control arm........all the same between your truck and a SRW 3500.
2006 EZ GO 6" lift
Old 06-19-2012, 08:51 PM   #40
Herk7769's Avatar
Would love to see something like that Ford document for the GMC.
air bags, led pad
