Old 04-28-2014, 06:06 PM   #11
Had to make a funny on the first post.IMHO you will be fine IF you watch what goes in the trailer that will affect tongue weight.Also load up and go weigh it.Have what you'll have when you travel.Have fun with it.
DaveandSue is offline   Reply With Quote
Old 04-28-2014, 06:07 PM   #12
thestrangebrew's Avatar
Originally Posted by markb5900 View Post
In simple terms, I think you are correct, But that roo can't have much more than a 3 or 4 hundred pounds TONGUE weight, so subtract that from payload as to what you haul.
Rockwood site says 344 lbs dry hitch weight, so I'd guess about another 100lbs. So 1212-444 = 768 for passengers and cargo? I think that would work. I'd say I have about 450 lbs between the 4 of us in passenger weight.
thestrangebrew is offline   Reply With Quote
Old 04-28-2014, 06:07 PM   #13
Herk7769's Avatar
This is a lot easier than you think these days.
The factory puts the max GVWR on a sticker on the door pillar.
Fill the tank, load up the family and put whatever gear you plan on carrying IN the truck; in the truck. Drive down to your local scale and weigh your truck.
SUBTRACT that weight from the pillar GVWR. This is the maximum tongue weight based on your remaining payload.
THEN divide that remaining payload by 0.125 (the optimum towing tongue weight - 12.5% of trailer weight) and you will get the target properly loaded camper weight you can tow.
If your remaining payload is 1212 pounds, divide 1212 by 0.125 and you get a camper weight of 9696 pounds.
If your actual loaded weight gives you less payload your camper selection gets limited.
FYI - for travel trailers (not 5th wheels) the MINIMUM tongue weight is 10% and the MAX is 15% of trailer weight with about 12.5% optimum for handling.
NEVER buy a camper using the minimum tongue weight percent as your selection criteria. You most likely will be unable to load it that light in the first place and the sway may be so severe you will need to get a more stable tow vehicle anyway.
HAM CALLSIGN - KC3FFW
Old 04-28-2014, 07:06 PM   #14
I would guesstimate your actual tongue weight to be 500-600 lbs, depending on how the trailer is optioned, how much gear you put in the front storage areas, how big your propane tanks and batteries are, etc... That means you are going to be looking at a weight distributing hitch (per Ford). Ford calculates payload as GVWR - wet weight of the truck as it left the factory (assuming a full tank of fuel) with nobody in it. So 1212 - 600 lbs (TW) - 50lbs (WDH) = ~562 lbs left for people and cargo. I like to keep about 700 lbs for people and gear, but you can probably work with 562 lbs.
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
Old 04-28-2014, 08:11 PM   #15
MtnGuy's Avatar
Originally Posted by thestrangebrew View Post
Initially that's what I thought, but I also swore I read that hitch weight and weight of passengers counts against payload. Can't seem to find the stuff I read though.
That is correct. What ever the 2 truck axles add up to is the gross weight of the truck.
We pull a camper with a 700 lb. tongue weight, and after adding the camper, camping supplies in the bed, a generator, the missus and me, plus a 85 lb dog, we are within about 100 lbs. of our GVWR (2006 F150 with a 7200 GVWR). But I will say the truck does great with all of that.
Old 04-29-2014, 07:33 AM   #16
AquaMan's Avatar
I don't think that's always the case.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 04-29-2014, 08:04 AM   #17
MtnGuy's Avatar
AquaMan, I am open to other ideas on that.
Old 04-29-2014, 08:19 AM   #18
Your truck will have no problem hauling a Roo 19 even being fully loaded with people and gear.
Old 04-29-2014, 08:21 AM   #19
This isn't actually an accurate statement. Every truck sticker I've ever seen, the GVWR has been lower than the combined axle ratings.
Old 04-29-2014, 08:22 AM   #20
Fulltime family RVer
Agreed, my GAWR front = 5,500 pounds and my GAWR rear = 9,350 pounds but my GVWR is only 12,300 (instead of 14,850) pounds. I know that some are willing to exceed GVWR as long as their under their axle ratings (and some are willing to exceed those, as long as they're under their tire load capacities and so on).
That said, I think the advice given so far is pretty right on. Herk, I'm not sure that the OP has bought his truck yet, so a trip to the CAT scales could be difficult.
Otherwise, anything in/on the truck goes against payload. Don't forget about traveling comforts- food, snacks, drinks, electronics, games, books, child seats, booster seats, bed cover, bed topper, the weight of the hitch, running boards, etc., etc. My truck's add-ons and my family eat up 1,200 pounds of our payload right out of the gate (doesn't help that I'm "big boned" ).
ependydad is online now   Reply With Quote
