How many axles do you have? 2 correct added them together for a weight rating of 10,400 LBS. Than you take between 15% to 20% of the camper weight (GVWR) (2,416.LBS) which is the pin weight that the truck will support. But to find your actual true weights, you should weight the camper and truck on a certified scale. Than weight each separately to find your true towing weights for your trailer and truck combination. Such as axles and pin weight of the trailer.
Most of us have down this and we also have weight the wheels on our trailers to find out the proper air pressure to run in your tires.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
