Originally Posted by rockfordroo
Too bad. Then all you need to order is the controller. It will come with a harness with 5 wires. You just hook them to the Tahoe's wiring with the included butt connectors. Not as easy as plug and play, but still not difficult. You'll also have to do the fuse box wiring thing. I still had to do that on my Silverado. Traverse was worse - needed a whole new fuse box - $128!!
sheripoms, the '07 and up Tahoes do not come with a plug'n'play harness and neither did my '07 Avalanche.
there's a bundle of wires that should have rubber bands around or zip ties. this is the bundle for the brake controller,
IF your Tahoe has the factory tow package.
i did as rockford roo mentioned, i used the OEM wiring harness that came with the Prodigy and spliced it to the bundle of wires.
Tekonsha has a great customer service dept. and will help you with any questions.
there's also a fuse in the engine compartment that needs to be activated to get power to the brake controller, once it's hooked up.
