Old 08-09-2016, 11:38 AM   #1
Considering 2013 310 BHDS Freedom Express Liberty Edition
I'm considering the purchase of a used 2013 310 BHDS Freedom Express Liberty Edition. Anyone have any experience with this unit and thoughts, also, I will be towing it with a 2008 Silverado 2500 HD Regular Cab with 6.0 V8 3.73 axel ratio and a Fastway E2 WDH...it's rated for 10,400 lbs...is that enough truck when the camper is 9900 GCVWR?
Thanks!
dfoxhoven is offline   Reply With Quote
Old 08-18-2016, 10:23 PM   #2
snapper's Avatar
310 freedom express
Hello
I own this exact trailer.. what year are you looking at? We have owned our for approximately 3 years. We choose this !model for all the room it has inside and the openness of the interior as well. The quality is above avg in reference to the interior wood and trim, as well as the fabric. I have had little issues with the interior components and fit. However I had several issues with the brakes getting hub grease that made its way into the breaking system. This was caused by cheap grease seals and the mechanics over packing the hub's with grease, causing pressure to build when the heat level raises. This occurred 3 times until the problem was resolved by my local mechanic. We used a quality seal that was made in America and synthetic wheel bearing grease that did not break down under heat. We also did not use the grease fitting inside the hub cover to grease the bearings. We did it the right way and removed the brake drum and packed them by hand. So far everything is great. I hope this helps you out. We like the trailer for so many reasons..
snapper is offline   Reply With Quote
2013, freedom express
