Old 06-21-2015, 08:35 AM   #1
considering 2304KS with Jeep GC as TV
Hello Forum! I'm very close to getting my first TT and seriously considering the Rockwood 2304KS. Had a couple newbie questions before I make a decision.
I have a 2014 Grand Cherokee with max tow rating of 6500 lbs. From all my research that seems like it should be fine for the 2304ks with a GVWR of 5023 lbs. Sound right?
It seems like the 5000 lbs GVWR with a tongue weight of 623 puts me into a class 4 hitch. Again, do I have that right?
Sorry if I'm asking the same questions that many have asked before. Just want to make sure I understood things. Thanks in advance for any help.
johncr is offline   Reply With Quote
Old 06-21-2015, 10:01 AM   #2
Charliec's Avatar
IMHO I would say you will defiately need a good WDH to compensate for the tongue weight capacity of your jeep (you did not say what the rating is but I bet its not over 500lbs). You will have to be careful how much weight you load in your trailer because 868 lbs. of cargo is not very much. You also need to consider the gross combined vehicle rating of your jeep and trailer. You may already know this but you should never count on the advice of a TT salesperson on towing matters. Enjoy your camping.
Charlie C
2012 Ford F-150
2015 Rockwood 2504S
Charliec is offline   Reply With Quote
Old 06-21-2015, 10:53 AM   #3
Georgia Rally Coordinator
aceinspp's Avatar
Most TT that give unloaded weight do not count in the weight of filled propane bottles or a battery on the hitch. Also adding fresh water is not figured in. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Old 06-21-2015, 11:22 AM   #4
Thank you both. Good advice. The max tongue weight on my Jeep is 620 lbs so it seems I'm pushing the limit. Does a good WDH give leeway on tongue weight or should I just go by the book so to speak?
Old 06-21-2015, 09:41 PM   #5
Charliec's Avatar
A WDH will double the tongue weight capacity. I use an equalizer hitch that works very well for me. They are at
Equalizerhitch.com
Charlie C
2012 Ford F-150
2015 Rockwood 2504S
Old 06-22-2015, 04:55 PM   #6
ablindmule's Avatar
With a good weight distribution hitch and good management of how much weight you are loading in there, you should be fine, but make sure you take the overdrive off when pulling. Ideally, you would not want to exceed 75% of your rating capacity
2015 Rockwood Roo 23 IKSS
2010 Ford F-150 Platinum 5.4L V8 SuperCrew 4x4 w Tow pkg
2017 nights camped: 15 so far, 6 more already planned
2016 nights camped: 7, wife was pregnant
2015 nights camped: 29
ablindmule is offline   Reply With Quote
