Old 09-22-2019, 02:00 AM   #1
Converting a fifth wheel hitch to use gooseneck bad?
I have been doing research on converting a 5th wheel hitch to use a gooseneck. My truck comes with the 5th wheel/gooseneck package. Would it make sense to do the conversion to save weight instead of using a traditional 5th wheel hitch mount?
2018 Apex 300BHS
2018 Ram 2500 HD Cummins
alvinmb is offline   Reply With Quote
Old 09-22-2019, 07:56 AM   #2
If 'weight' is your only consideration, the Andersen Ultimate is the frontrunner.
There are many posts on this site about the pros/cons of gooseneck attaching hitches.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 09-22-2019, 10:51 AM   #3
So the Anderson is better than using the built in puck on the truck bed? With the low payloads on 3/4 diesels, every little bit can help.
2018 Apex 300BHS
Old 09-22-2019, 12:01 PM   #4
'Better' is subjective.
Again, if weight is your big concern, the Andersen (not Anderson) wins hands down.
The Andersen does not use the outer factory puck holes, only the gooseneck ball mount center hole.
As I said previously, there are a ton of 'what is the best hitch' threads on this (and all R/V) forums.
What I think best may not even register on the next three guy's scale.
Read up on the various different hitches and if you have specific questions, ask away. Only you can decide what is 'better/best.'
Old 09-22-2019, 01:01 PM   #5
SeventyGTX's Avatar
The Andersen Ultimate is made to use on a gooseneck ball. I use an Andersen with the factory 5th wheel prep and B&W gooseneck ball kit. Works awesome. However, Andersen now makes a Bed Shaft that goes into the factory puck to use with their hitch at about 1/3 the price of the B&W kit. I would go that route if I didn't already have the B&W....
2016 Wildcat Maxx 262RGX
2016 Ram 2500 Laramie Longhorn 4x4 Cummins 6.7 CCSB Factory Auto-leveling and 5th Wheel Prep w/B&W ball kit, Andersen Ultimate
https://www.forestriverforums.com/attachments/signaturepics/sigpic98816_1.gif
SeventyGTX is offline   Reply With Quote
Old 09-22-2019, 01:20 PM   #6
Many 5er frame manufacturers do not allow the use of a gooseneck adapter because of the added stress on the hitch box.
Sealyn is offline   Reply With Quote
Old 09-22-2019, 01:27 PM   #7
SeventyGTX's Avatar
Another way to get out of a warranty claim which they are masters at.
Old 09-22-2019, 01:42 PM   #8
Retired Member
rmwmiata's Avatar
Checkout Reese Goosebox, I believe that is correct name. I understand it will not void warranty.
Pam and Murry Wilbanks
2018 SIERRA 377 FLIK
2018 Ram Laramie 3500 DRW
rmwmiata is offline   Reply With Quote
Old 09-22-2019, 01:47 PM   #9
Just to be sure everyone is on the same page... gooseneck ADAPTERS are entirely different than an Andersen Ultimate that connects to a gooseneck center ball.
And I'm certainly not portraying being an Andersen fanboy but I believe they back that hitch with a multi-million dollar policy if your trailer/tow vehicle warranty or insurance says no on frame issues.
Plus they'll give you $500 for you inconvenience.
Can't use that as a negative any longer when arguing pros/cons.
Old 09-22-2019, 01:56 PM   #10
Georgia Rally Coordinator
aceinspp's Avatar
System I'm considering. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 54
aceinspp is online now   Reply With Quote
Old 09-22-2019, 01:58 PM   #11
Mr. Dan's Avatar
Gooseneck ADAPTERS are entirely different than an Andersen Ultimate.
Yes, this ^^^^.
I recently had to have a fairly major repair (welding in new metal, etc.) to the structure around my pin box. The extended service contract holder AND the frame manufacturer made me prove I had been using the Andersen Ultimate and NOT another Andersen product that is a gooseneck adapter. The manufacturer sent parts for free and instructions on the best practice to repair.
BTW, mine is the original black steel Andersen Ultimate... so mine is heavy - 75 pounds total!
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 09-23-2019, 03:34 AM   #12
I installed a Gooseneck hitch on our 2017 Ram 3500. Had Dealership install a 20K Reese gooseneck air cushioned pin box on the RV.
Our only regret with this set up is loss of box space when hooked up (travelling). Pin box sits low in the truck box so have to consider swing. RV is designed for 90 deg swing. Need to consider swing on side to side and behind pin.
We will take the bed loss over the annoying chucking.
Hardly feel our 42' fifth wheel in tow with the gooseneck/air cushioned set up.
Our bonus is getting to a site, unhook, flip the gooseneck ball...full box.
Getting too old for hauling out a filth wheel hitch when I need a full box.
It all comes down to preference...what are your needs.
Arnie M is offline   Reply With Quote
Old 09-23-2019, 06:05 AM   #13
I have been using the Andersen Ultimate Aluminum hitch for 4 years now. I love the light weight and how easy it is to remove.
I did have some frame flex issues and LCI tried to blame my hitch. They claimed that my hitch was causing the issue but they couldn't prove it. In the end LCI added additional gussets to fix the issue. Andersen was willing to stick behind their warranty if LCI could prove the hitch was the issue.
I still like and use my Andersen in my 3/4 ton diesel.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=40
Electra glide is offline   Reply With Quote
Old 09-23-2019, 07:48 AM   #14
jtatum65's Avatar
I to was looking to switch to the Andersen Ultimate due to the heavy weight of my old Curt hitch w/ ram legs. It was too heavy for me and my wife to get out of the truck, it took 2 men and a baby elephant to get it out. So while looking at 3 different options....
1. Andersen Ultimate - Didn't comfortable with the aluminum frame (just my opinion)
2. Reese Goosebox - too expensive
3. Pullrite single point hitch - Which I choose.
The Pullrite is like the Andersen hitch it attaches to the gooseball in the bed of truck. The difference is it is an inverted design. Meaning ball on the pinbox and cup receiver on the hitch. But reasons I chose the Pullrite hitch was for the following....
1. Weight - 54lbs
2. All steel construction
3. Cost - $575 from RV Parts Pro on Ebay.
4. Takes up half the space in the bed of the truck compared to the Andersen.
So far I have pulled my 12k FW approx 1000 miles have not had any issues with the ride, actually the ride is much better as like the Andersen hitch, it eliminates a lot of chucking. Also talking to Pullrite, they say they will back this hitch all the way to court if need be to provide the hitch will not damage the pinbox or the frame. According to a manager I talked to at Pullrite, they have already had a lawsuit against LCI regarding their claim that the Pullrite hitch will damage the frame and apparently they won, according to the manager.
Jim & Evelyn Tatum
2018 Shasta Phoenix 336RL FW
2016 Dodge Ram 2500 Big Horn 6.4L Hemi 4x4
Nights Camped 2019 = 32
Nights Camped 2018 = 28
Nights Camped 2017 = 27
jtatum65 is offline   Reply With Quote
Old 09-23-2019, 07:56 AM   #15
Brendon37's Avatar
I use the Andersen in my Ram and I love it. The Reese Goosebox is also another good option to save some weight.
2014 Ram 2500 4x4 Laramie 6.7 Cummins
2017 Prime Time Crusader 315rst
B&W Turnover Ball
Andersen Ultimate 5th Wheel Connection
Dish Wally w/ Pathway X2
Brendon37 is offline   Reply With Quote
Old 09-23-2019, 10:35 AM   #16
SeventyGTX's Avatar
Yes, I realize they are completely different. Just stating my thoughts on the manufacturers and suppliers (Lippert in this case) regarding warranty.
Old 09-23-2019, 11:12 AM   #17
Fulltime family RVer
I had the Andersen Ultimate for 4 months. My fifth wheel is very pin light (15% on a 21,000 lbs setup). The ride with the Andersen was horrendous. Shook us up in the cab and caused my wife pain.
Plus, it would always twist in the bed. There was a thread here on FRF about it, so I was "happy" to read I wasn't alone in that.
Old 09-23-2019, 11:23 AM   #18
SeventyGTX's Avatar
Sorry to hear about your issues that are definitely in the minority, there are thousands of us out there that love them. But that's the first I ever heard of a "horrendous" ride. But I suppose bantering back and forth about that is for another thread.
Old 09-23-2019, 12:24 PM   #19
Thank you for the picture attachment.
2018 Apex 300BHS
Old 09-23-2019, 12:25 PM   #20
That is the confusion I am reading into. At this time, I am just researching as my time frame is probably a year out, just planning ahead. With the limited payload the Ram 2500 w Cummins, it may be best I stay with bumper pull. Time will tell.
2018 Apex 300BHS
fifth wheel, hitch, wheel
