04-15-2012, 10:38 PM
crosswinds are scary!
Just back from a "shakedown cruise" with our new Apex 288BHS.. Camper was wonderful on site, but..Encountered strong gusting winds which really had me nervous on the way back.. Mileage in the explorer dropped from the meager 13 we usually get towing to about 7 mpg against the wind! Was wondering if perhaps filling my freshwater and grey tanks (30gal each)might help to cope with the wind.. The 288 is a sail in gusty wind, even with my WDH with separate swaybar.. Found my best immediate solution was to slow down when the buffeting got too much.. I'd appreciate any advice from the learned members on here.. Towing with a 2006 Explorer with 4.5L v8 with towing package and the aforementioned WDH and sway bar..
thanks
04-15-2012, 10:52 PM
We also camped this weekend(check out before a longer trip this week), with us narrowly missing the big storms coming in. Had very gusty winds going home, but I have 2 friction sway bars with my 28' TT. Did not feel any sway as we just got home just before it poured down(here in Missouri).
2006 Rockwood 8272S
2005 Chevrolet Silverado
John & Pandra
Battlefield, Missouri
F.R.O.G. Member
1st International F.R.O.G. Rally Branson Missouri
04-15-2012, 10:55 PM
That camper may not weigh an excessive amount, but it is HUGE compared to your tow vehicle. That is probably your biggest problem, the tail is wagging the dog!
I doubt that filling your tanks would help much, as it would just make the camper harder to pull, and depending where they are located, could make the situation much worse.
I think you'll just have to avoid high winds, as you may simply have too much camper for your tow vehicle.
04-16-2012, 12:19 AM
Originally Posted by caziii767
JTowing with a 2006 Explorer with 4.5L v8 with towing package and the aforementioned WDH and sway bar..
thanks
the fact you're towing a 31' TT with a small v-8 Explorer, says it all!
soft suspension, under-powered engine, short wheelbase and a cheap friction bar for antisway.
i assume the dealer told you that you could "tow that".
04-16-2012, 12:45 AM
Man, I'm new at this, too... but we hit some substantial (30mph+) x-winds down around Liberal, Kansas this past March that were buffeting us directly from the side. Slowing down was all I could do to feel safe.
Jim & Kathy
2012 Crusader 290RLT TE, TrailAir flex pin: 2012 Toyota Tundra 5.7 SR5 Dbl cab 4X2 Tow, 4.30 gears, RideRite air, TRD cold-air induction & dual exhaust: Reese 16K Slider: TST tpms
Miles towed to date: 26,890; Nights camped; lost count!
04-16-2012, 05:05 AM
Slowing down is the smart thing to do in heavy crosswinds. Adding water weight to the trailer is the wrong thing to do. Doing so will only add to the leverage your trailer already has on you and will decrease your MPG even further.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
04-16-2012, 06:19 AM
I switched from a round bar style WDH with 1 Friction sway control over to an equalizer hitch.... night and day difference with how the set up handled cross winds.
2013 Ford F150 Super-Crew
2014 Heritage Glen 312qbud
04-16-2012, 07:12 AM
The explorer handles the trailer well. The trailer weighs in at 4580 dry and 7200 fully loaded. Explorer is rated to tow 7500 with the weight distribution hitch . It tows 5000lbs in class III. I have not had issues towing with it before. I think the length of the trailer and the fact that it is a sail are the problem.
04-16-2012, 07:26 AM
Thanks to all for the collective wisdom. I will attempt to plan my trips around the weather and will slow down, or pull off if necessary and wait it out. It makes perfect sense that adding 500 lbs in water weight will only have the effect of further diminishing the mileage and making the tow unstable. I was concerned about the vehicle weight ratios and researched the issue. I had my doubts about it as well, but the explorer towed it easily ( in calm weather) and my mileage dropped from the usual 19mpg (sans trailer) to about 11. (We had a 3500lb pop up previously which dropped the mileage down to 14.) I would definitely like to have more vehicle in front of it, but it is supposed to be up to the task.. Of course, the Titanic was supposed to be unsinkable ,too. Thanks to all.
04-16-2012, 07:30 AM
" the explorer towed it easily ( in calm weather) "
Indeed. I could pull a fifty foot trailer "in calm weather", but would I?
04-16-2012, 08:02 AM
point taken. thanks
04-16-2012, 08:18 AM
pulling over in a safe place
most all of us a towing
know the feeling
and it never feels good
but
all usually turns out well
there is a spot on Interstate 8 near by
where rigs do blow over occasionally
but
the Highway Patrol closes
when conditions are dangerous
for big rigs and RV's
have seen side winds that almost stopped me
takes more than we think to flip
but
is always better than
turning oven in an unsafe place
Mountainman
04-16-2012, 08:25 AM
I used to pull a 27' trailer that weighed about 5200# with an '08 Explorer with the tow package. As you mentioned the vehicle is more than rated to pull that sized trailer unlike all these people pulling 5'ers with Tundra's. I use a 10k Equal-i-zer hitch. I can remember coming back from Virginia Beach a couple of years ago. There were some nasty cross winds. I had no trailer sway but it certainly push the vehicle and trailer sideways. My guess is you would enjoy trailering a lot more with a better hitch.
2012 Lacrosse 318BHS
2010 F-150 Max Tow
