Old 12-05-2019, 08:54 PM   #1
Cruise Control
I am towing for the first time in 20 years and have a question about cruise control. I remember back in the 90ís my owners manual said not to use cruise control when towing. In my new truck manual it doesnít mention anything about using cruise when towing. I was wondering if there would be an issue using cruise when travelling down the highway. I have a 2019 Dodge 3500 diesel DRW. My 5th wheel is 43í with a GVW of 18000.
Dan and Carol
2019 Ram 3500 DRW/crew cab/4x4/long box
2019 Cedar Creek Hathaway 38FLX
Full timers since May 2019
Axeman49 is offline   Reply With Quote
Old 12-05-2019, 09:11 PM   #2
I use my every time I tow. Iíve pulled for 10s of thousands of miles and no issues. I even use it on long steep downgrades with assist from my diesel brakes.
2016 Siverback 33IK
Old 12-05-2019, 09:12 PM   #3
007matman's Avatar
Is it constantly shifting out of overdrive? My guess would be no.
The only time I don't use the cruise is if I'm towing with a vehicle that is constantly shifting down. Otherwise, I'll run the cruise.
Edit: I should clarify.. Only if it's downshifting to go up hills constantly and the REV's are getting really high. Downshifting to go down hills is a good thing.
007matman is online now   Reply With Quote
Old 12-05-2019, 09:13 PM   #4
Rigpdx's Avatar
I use it all the time! Set somewhere between 60-65 hauling my 42ft Crusader. Rides up and down hills with ease thanks to the 6.6 and exhaust braking. Can't see any reason not to. Enjoy and relax!!
2014 Crusader 351 REQ Touring Edition (the Cottage)
2015 GMC Sierra 3500HD SLT (Allison B)
Nights in the Cottage: 2014: 27, 2015: 80 2016: 47,[B]2017:41
2018: Jan= 2, Feb=2, Mar=3, Apr=2, May=7, June=5, July=15, Aug=1,Sept=2,
Running Total:232
Rigpdx is offline   Reply With Quote
Old 12-05-2019, 09:47 PM   #5
rracer5's Avatar
X4 Your 6.7 CTD will pull that trailer all day in cruise control & not think twice about it! These newer trucks all have "smart engines & transmissions" and in tow/haul mode with engine brake engaged it will do everything possible to keep you rolling (and stopping) smoothly.
It may actually may come down to more of a comfort thing. Some drivers are not comfortable using cruise control when doing (towing) anything they're not completely comfortable or familiar with & prefer to "feel" everything manually.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 12-05-2019, 10:35 PM   #6
Fulltime family RVer
I use it almost all the time I tow because otherwise I can’t drive that slow!
Old 12-05-2019, 11:29 PM   #7
Fluffywhitedogs's Avatar
I use it almost all the time I tow because otherwise I canít drive that slow!
X2
Carmen and the pack
2015 Coachmen Clipper 17BH
2017 Dodge Durango Citadel 5.7 Hemi
Fluffywhitedogs is offline   Reply With Quote
Old 12-05-2019, 11:41 PM   #8
Cruise
Thanks for all your replies. I will give it a try and see how I like it.
Dan and Carol
Old 12-06-2019, 01:24 AM   #9
I use it ALL the time especially since its adaptive cruise control. Makes driving way less tiring.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 12-06-2019, 06:21 AM   #10
I use mine towing...BUT !!! it also depends on the road conditions. Heavy rain ? NO !, Foggy ? NO !, High Winds ? NO ! otherwise...it's "set it and forget it."
TheWolfPaq82 is offline   Reply With Quote
Old 12-06-2019, 07:10 AM   #11
frank4711's Avatar
Always use it
Frank & Cindy ... Rockwood 2888WS Ultra Lite 5th Wheel---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed---Remi & Sage camp pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Goodyear Endurance ... Predator 3500---48 days 2019--- *** Payload 4394 ***
frank4711 is online now   Reply With Quote
Old 12-06-2019, 08:34 AM   #12
use it! and then adjust your speed as required using the up speed / down speed buttons. as somebody mentioned it will keep your speed at 65 as opposed to my foot that somehow keeps pushing further down on the accelerator.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 12-06-2019, 09:54 AM   #13
Failure is my business
2Evil4U's Avatar
Biggest thing with mine is if there are hills. It overshoots at the top and has to use the exhaust brake on the down hill. So I run hills manually. Otherwise. I use it all the time.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 16 Flagstaff 832IKBS, 14 RAM 1500 4x4 Hemi 3.92 Bilstein 5100's Derale oil cooler, 97 F150 4x4 5.4L 278,000 miles, 80 Firebird Esprit Aussie Burnout Car https://youtu.be/v06VjII7HmE, 78 Harley Davidson FX 79,000 miles dad bought new, 71 El Camino ZZ3 TH400 12-Bolt, 37 Ford 3 window 502 Chevy dad built
Days Camped: 2016: 43, 2017: 83, 2018: 44, 2019: 78
2Evil4U is offline   Reply With Quote
Old 12-07-2019, 10:50 AM   #14
Unless the CC forces a downshift, I use it all the time.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
