12-05-2019, 08:54 PM
Cruise Control
I am towing for the first time in 20 years and have a question about cruise control. I remember back in the 90’s my owners manual said not to use cruise control when towing. In my new truck manual it doesn’t mention anything about using cruise when towing. I was wondering if there would be an issue using cruise when travelling down the highway. I have a 2019 Dodge 3500 diesel DRW. My 5th wheel is 43’ with a GVW of 18000.
Dan and Carol
2019 Ram 3500 DRW/crew cab/4x4/long box
2019 Cedar Creek Hathaway 38FLX
Full timers since May 2019
12-05-2019, 09:11 PM
I use my every time I tow. I’ve pulled for 10s of thousands of miles and no issues. I even use it on long steep downgrades with assist from my diesel brakes.
12-05-2019, 09:12 PM
Is it constantly shifting out of overdrive? My guess would be no.
The only time I don't use the cruise is if I'm towing with a vehicle that is constantly shifting down. Otherwise, I'll run the cruise.
Edit: I should clarify.. Only if it's downshifting to go up hills constantly and the REV's are getting really high. Downshifting to go down hills is a good thing.
12-05-2019, 09:13 PM
I use it all the time! Set somewhere between 60-65 hauling my 42ft Crusader. Rides up and down hills with ease thanks to the 6.6 and exhaust braking. Can't see any reason not to. Enjoy and relax!!
2014 Crusader 351 REQ Touring Edition (the Cottage)
2015 GMC Sierra 3500HD SLT (Allison B)
Nights in the Cottage: 2014: 27, 2015: 80 2016: 47,[B]2017:41
2018: Jan= 2, Feb=2, Mar=3, Apr=2, May=7, June=5, July=15, Aug=1,Sept=2,
Running Total:232
12-05-2019, 09:47 PM
X4 Your 6.7 CTD will pull that trailer all day in cruise control & not think twice about it! These newer trucks all have "smart engines & transmissions" and in tow/haul mode with engine brake engaged it will do everything possible to keep you rolling (and stopping) smoothly.
It may actually may come down to more of a comfort thing. Some drivers are not comfortable using cruise control when doing (towing) anything they're not completely comfortable or familiar with & prefer to "feel" everything manually.
2014 Prime Time Sanibel 3250
12-05-2019, 10:35 PM
Always Learning
I use it almost all the time I tow because otherwise I can’t drive that slow!
12-05-2019, 11:29 PM
X2 [emoji16]
Carmen and the pack
2015 Coachmen Clipper 17BH
2017 Dodge Durango Citadel 5.7 Hemi
12-05-2019, 11:41 PM
Cruise
Thanks for all your replies. I will give it a try and see how I like it.
Dan and Carol
12-06-2019, 01:24 AM
I use it ALL the time especially since its adaptive cruise control. Makes driving way less tiring.
12-06-2019, 06:21 AM
I use mine towing...BUT !!! it also depends on the road conditions. Heavy rain ? NO !, Foggy ? NO !, High Winds ? NO ! otherwise...it's "set it and forget it."
12-06-2019, 07:10 AM
Always use it
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
12-06-2019, 08:34 AM
use it! and then adjust your speed as required using the up speed / down speed buttons. as somebody mentioned it will keep your speed at 65 as opposed to my foot that somehow keeps pushing further down on the accelerator.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
12-06-2019, 09:54 AM
Failure is my business
Biggest thing with mine is if there are hills. It overshoots at the top and has to use the exhaust brake on the down hill. So I run hills manually. Otherwise. I use it all the time.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 24 Cedar Creek 40CBK
12-07-2019, 10:50 AM
Unless the CC forces a downshift, I use it all the time.
