Old 05-30-2013, 07:52 AM   #1
Crusader 295 rst 2013 Fifth Wheel
Does anyone have any info on towing this rv with a 2009 F-150? My owners manual says it has a towing capacity of 11,300. The rv weighs approx. 9,000 empty. I want to buy this rv and am researching if i need a bigger truck.
tnseavol is offline   Reply With Quote
Old 05-30-2013, 08:08 AM   #2
Absolutely you need a bigger truck!
It's not towing capacity that matters for RV's. It's pin weight (or tongue weight) compared to your Cargo Carrying Capacity (GVWR - weight of truck and passengers and other cargo). Rear GAWR must be considered as well.
For a 5er, the pin weight will be between 15% and 25% of the LOADED weight (not dry weight). For this trailer, that's .25 * 11900 = 2975 pounds. Oh, and don't forget about the weight of the 5th wheel hitch.
Old 05-30-2013, 08:09 AM   #3
Scratch's Avatar
Could an F-150 pull it? Probably, with great effort. Could a 1/2 ton truck stop it safely? No.
l
Highly recommend a 3/4 ton or bigger for the 295RST. In fact; most here will advise not to pull any 5th wheel with a 1/2 ton truck. Many threads on this topic...
Scratch sends...
'12 nights camped: 12
'13 nights camped: 24
'14 nights camped:
Scratch is offline   Reply With Quote
Old 05-30-2013, 10:49 AM   #4
towing
Thanks for the info, i figured a bigger truck and i knew u guys would have the experience to send me down the right road.
Old 05-30-2013, 11:00 AM   #5
l
Trailer should stop the same whether 1/2T or 3/4T, I would definitely not put that much pin wt in any 1/2T or 3/4T.
Old 05-31-2013, 09:14 PM   #6
ddphillips52's Avatar
I have a 2013 295RST and have had it weighed. The trailer weight is 10,500# loaded for camping with a 2,000# pin weight. I pull it with a 3/4 ton GMC. Total for truck and trailer is 17,500#.
Dennis, Linda, and Scout the Dog
2015 Mesa Ridge 347 RES
Husky 16KW with Reese Sidewinder
2013 4WD RAM 3500 Cummins TD SBCC
ddphillips52 is offline   Reply With Quote
Old 06-01-2013, 10:42 AM   #7
Scratch's Avatar
Most reasonable folks would agree that a larger truck with beefier brakes and sturdier frame will stop a large trailer much more comfortably and safely than the 1/2 ton counterpart. Most 3/4 ton (and larger) truck owners will attest that a downhill 'panic stop' from 55 mph or so is uncomfortable at best. That large trailer will control the smaller truck in a similar panic stop scenario.
Based on the responses to your inquiry, the trailer you are considering is too much for a 1/2 ton truck. Consider your family's safety and the safety of fellow travelers. Matching the trailer's profile to the TV's designed capabilities/specs are important parts of the buying process. Once you've purchased, get used to the pulling/driving experience; then hit the road and have some fun...
Scratch sends...
'14 nights camped:
Old 06-01-2013, 12:18 PM   #8
zs325RES's Avatar
Sound advice here.
Buy the trailer!, but get a 3/4 ton truck to tow it with. You won't be sorry.
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider (not necessary), Air Lift bags & Black Bear Performance tune & CAI
Norm & Karen Zondervan
zs325RES is offline   Reply With Quote
Old 06-01-2013, 12:54 PM   #9
Camper Less Camping
Cajun Po-Boy's Avatar
l
X2!!!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 06-01-2013, 02:50 PM   #10
Forget the 3/4 ton and go right to the 1 ton. Not much difference in cost and even with a 3/4 ton you'll be pushing payload and next you'll be asking about airbags or sleeper springs. I speak from experience.
Bruce & Lori, both Retired, Charli (60 lb lap dog)
2011 F350, KR, 6.7L PSD, 6 1/2' box
2015 Mountaineer 331RLT
Charli is offline   Reply With Quote
