Old 07-08-2015, 10:40 AM   #1
Crusader plus Ram 2500 too high!
1st 5th wheel, and we are sitting at 13'2", with a 2015 Ram short bed diesel, factory air ride and 5th wheel prep. Long time 5th wheel owner and engineer friend recommended the Reese sidewinder. Our hitch guy installed with B&W companion receiver and says we are as low as we can go. We have the Crusader 315 RST and are really concerned about our down the road height. Should we look for a lower receiver to rectify (our is sitting at 17")?
Should we put the factory pin box back on?
Kshryne is offline   Reply With Quote
Old 07-08-2015, 10:41 AM   #2
Left Coast
Trailer level?
Old 07-08-2015, 10:52 AM   #3
TURBS's Avatar
13' 2" is legal
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 07-08-2015, 11:42 AM   #4
Trailer isn't level, front sits up really highp
Old 07-08-2015, 06:38 PM   #5
CWSWine's Avatar
We have a 315RST and B & W hitch but we have a 2015 Ford F350. We were riding a couple of inches high in the front and we solved it by lowering the hitch arms as low as they would go and also raised the pin box on the 5th wheel as high as it would go. We are less than 1/2 inch from being level but all is left is messing with the 5th wheel suspension and just not worth it at this point. Out 5th wheel axles were already flipped and there was no shackles we could adjust. We towed almost 1200 miles this month and towed though some mid-west thunder storms without any problems.
If I'm not mistaken all US FEDERAL highways overpass are suppose to be 14+ feet but some state highways do have lower overpass. Like this one
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 07-09-2015, 10:17 AM   #6
Dave_Monica's Avatar
Your height is about average for most 5th wheels...nothing to worry about. As far as towing level, you should measure the frame to ground on the camper both front and rear while hooked to the truck and on level ground. As the camper axles are the fulcrum, if the camper is 3" higher in the front, it only need to be lowered 1.5" to be level. Another consideration is the clearance between the camper's overhang and the top of the truck's bed rails...shouldn't be less than 6". If the camper is nose high and you're already at 6" clearance above the bed rails, no adjustment to the hitch or pinbox can fix that condition...either raise the camper, lower the truck or live with it.
Dave
Old 07-09-2015, 10:33 AM   #7
Left Coast
After changing hitches on my set-up, I had to raise pin-box as much as possible and lower truck....cost nothing to do, just a little time and have enough rail clearance.....also, trailer has torsion type axles.
Old 07-09-2015, 12:33 PM   #8
Tall Ram 2500
The guy who installed my 5th Wheel setup said he was glad I didn't have the auto level because it would have raised my truck back to its original height after the load from the Crusader was applied. As it is, the truck sinks about 2-3 inches after the 5er load and all is level.
wshelton1 is offline   Reply With Quote
Old 07-09-2015, 12:40 PM   #9
avolnek's Avatar
I recently purchased a new 5th wheel towing with a 2015 ram 2500 as well. I however installed rails and am running a Curt Q16 hitch with manual slider. My hitch head sits 18" off the bed of the truck. I love it being that high, makes it easier to see when backing up to hitch up. It also puts the pin box high enough above bed rails to clear with my tonneau cover, which clamps on the inside of the rails.
My hitch is actually as low as it will go. With it hooked up the camper over hang is 7-8" above the bed rails which is ideal for me. However i sat significantly higher in the front of the camper in relation to the back. To correct this issue i actually raised the camper. Mine had adjustment holes where the leaf springs bolt to the frame of the camper. I simply jacked the camper up, pulled the bolts and dropped the suspension....
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 07-09-2015, 01:07 PM   #10
Jim34RL's Avatar
My unit is 13'-6" to the top of the front A/C cover shield and I sit level with my Cedar Creek when hitched up to the truck. I have a 16K Reese sliding hitch and the Trailair pin box on my unit. I just need to be careful around low overhangs and bridges. My GPS unit is programmed with the trailer height in it.
My gap between the bed rails and underside of the fiver is 6" which I am comfortable with.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
500, crusader
