12-27-2013, 04:33 PM
Curt 16245 Q24 Fifth Wheel Hitch
Was wondering if any of you out there in 5th wheel land have or are currently using this hitch?
https://www.curtmfg.com/part/16245
I currently am using a Curt 16K swivel rocker which is very capable of handling our Wildcat 353LS.
https://www.curtmfg.com/part/16115
But, I do like the idea of having two separate jaws close tightly around the kingpin and taking up any slop from like with a basic hitch.
2018 Berkshire XL 40B
Past RVs: National Pacifica 40', Kenworth T300 Toterhome, Jayco Class C 32'. American Eagle 40',
American Eagle 40', Bounder 38' tag axle
12-27-2013, 04:54 PM
I've got the Q20 with the roller slider. It's the same operation as the 24k. The 2 jaw is a nice system and been trouble free for 3 years and 10k miles.
12-27-2013, 05:17 PM
Thank you for the quick reply. Sounds like it would be worth the $514 cost.
12-27-2013, 06:43 PM
I also own a Q20 and it works great. This is my first fw hitch and has it has taken me a bit to back into it the first time but after a few pulls I got better at it. It is nice solid hitch and really quiet compared to others.
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
12-27-2013, 07:02 PM
I have a q20, non slider. No complaints. Regular lube where it indicates and that's all.
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
12-27-2013, 07:12 PM
Thank you for the feedback!!!!
12-27-2013, 07:29 PM
Now a "Top Member"
Q20 slider here also, and no problems. A good, if heavy, hitch. Does what it needs and does it well.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
12-27-2013, 07:36 PM
I went from the Curt E16 to the Q20 and I like it a lot. It sounds like you have the same setup as I did. The Q20 is what you will want for your wildcat. All of the "slop" is eliminated, and I use shims between the rails and hitch to eliminate any play in the pins. I really like the Curt hitches for their build and price. Not sure they can be beat.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
12-27-2013, 07:39 PM
I too have the Q20 and I love it!!
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
12-27-2013, 07:41 PM
Hey Timmy, were your shims rubber. I had them before I had to remove the hitch, when I went to put it back in i could not get the pins in with the shims on. So now they are just inside my truck!! I seen this so I thought I would ask you about it.
Scott & Vicki
2021 4 reserved
12-27-2013, 07:49 PM
I had the rubber ones, but they tended to wear quickly. I made shims from aluminum and hammered my pins in when I had the weight of the trailer on it. Not really conducive to removing the hitch a lot, but I only remove it when necessary. I'm thinking around .080-.100 usually made it snug.
12-27-2013, 08:43 PM
Lot's of great feedback and information shared here, and it is all appreciated.
