07-07-2018, 02:12 PM
Always Learning
Curt X5 gooseneck to 5th wheel rails adapter - sloppy
I bought a Curt X5 gooseneck to rails adapter plate for installing my hensely Trailer Saver TS3.
I emailed Curt today, but being a weekend, I don’t expect a response. But, this just looks bad.
https://youtu.be/dVP789tDCwQ
07-07-2018, 05:18 PM
There are a set of thin rubber shims that are supposed to go under the rail plate and that takes up the slack that you're seeing. However, even without the shims the rails will sit hard on the bed once you're hooked up.
Gotta go campin!
07-07-2018, 11:40 PM
Yikes, does that clamp around the ball and tighten down or does it go in the square socket like the b&w?
2013 Palomino Sabre 34TBOK. '13 F-350 KR CC DRW 6.7
Working hard to pay to play!
07-08-2018, 12:06 AM
Never mind, I googled it. That is a lot of slop in my mind. Interested to hear what they have to say
07-08-2018, 12:22 AM
Mine does the same
07-08-2018, 12:39 AM
Always Learning
Down into the square socket. So it’ll limit how far it rotates, but it has to be hard on everything with that kind of movement.
Always Learning
Originally Posted by Aztec1382
Mine does the same
How heavy are you towing and has it caused any issues?
07-08-2018, 12:41 AM
Always Learning
There were four 2”x3” rubber pads that 2 came off before I got it out of the box. But they can’t be thick/tough enough to do a lick of good.
07-08-2018, 02:25 PM
I am not familiar with that type of hook up BUT although the rails are not bolted to the bed allowing for easy removal and leave the bed open I would not use that set up.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
07-12-2018, 10:21 PM
What was the resolution on this?
07-13-2018, 08:27 AM
Always Learning
None yet. No response from Curt. I guess I am going to need to call them.
