Old 05-23-2013, 11:53 PM   #11
Sgt. Schultz's Avatar
I would suggest that your friend start with the basics - fresh fuel filter, oil change, check & replace the air filter as required, if it has not been done change the axle fluids & tranny fluid, a diesel purge would also be a good idea IMHO - DIY DIESEL INJECTOR SERVICE
The following may also offer some suggestions Smoke Tells A Story
PT Avenger 33BHS-TE
GMC 2500HD SLE 4x4 Crew Cab 6.0 with 4.10's
Sgt. Schultz is offline   Reply With Quote
Old 05-24-2013, 09:39 AM   #12
daydreaming about camping
jeeplj8's Avatar
Excellent advice!!
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 05-24-2013, 10:06 AM   #13
Camper Less Camping
Cajun Po-Boy's Avatar
X2
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 05-24-2013, 10:17 AM   #14
I have a 2011 2500HD D-MAX. I get around 14mpg city 22 hwy and about 11.5 towing my 5th wheel that weighs about 13K loaded for camping.
Soxfan1957 is offline   Reply With Quote
Old 05-24-2013, 10:30 AM   #15
Resident Masshole
force's Avatar
Just to compare gas v diesel, I have a 2013 GMC 2500 HD Crew cab w/ the 6.0L gasser and 3.73's, and I'm getting no better than 10mpg towing a 5800lb Roo, and my empty city/backroad mileage is around 14mpg.
Granted, I have only 700 miles on the thing, and am trying really hard to evolve from my lead foot days, but I thought it might get better than this. Almost regretting not sticking w/ a half ton.
Almost
Tom F.
2013 GMC 2500HD SLT Crew Cab
2013 Rockwood Roo 23SS
Nights camped in 2014: 8
Nights camped in 2013: 30
force is offline   Reply With Quote
Old 05-24-2013, 10:45 AM   #16
I used to have a 2004 2500HD 6.0L gasser and that thing couldn't pass a gas station.
Old 05-24-2013, 11:02 AM   #17
Roadie66's Avatar
Wow those are some great mileage results! I have a 2011 2500 Duramax with the 6 speed and BEST I get on the highway with about 700 lbs of tools etc at 70 mph is 18mpg. Closer average is 16mpg.
What are you guys doing to get 21mpg??????
Home is where the hookup is!!
2011 Silverado 2500HD Duramax LTZ tailgated by a 2012 Crossroads ST25RB Reserve
Roadie66 is offline   Reply With Quote
Old 05-24-2013, 11:19 AM   #18
TURBS's Avatar
Feather foot!
Old 05-24-2013, 01:05 PM   #19
jevanb's Avatar
Almost
when did GM start putting in 3.73`s in the HD that was the option in the LD and the only gear set you could get in the HD`s was the 4.10. I ordered and that was the only option, unless you got the dmax
first off keep the stock pizza cutter aired to 80psi, slow starts, take foot off pedal a long way back and coast to a stop
I had one also and it was a gas hog...
I currently get 16city 22hwy, towing the 12.7k 5er I see 12.5 all day. I am far from stock, execpt for the tires.... replace the rear diff fluid with mobil 1 syn gear lube 70-90w, and also do the front and tcase, your rear is 1qt low from the factory, so do this ASAP 4qts will fill it, the tcase fill with 5w30 syn motor oil 2qts, and front 2 qts of mobil 1 gear lube 70-90w. this should help on the milage. their are a few other things that will help but it will cost about $1500.00 and in the long run pays for it`s self real fast, like EFI tuning, and a exhaust from the turbo outlet back
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 05-24-2013, 01:57 PM   #20
Camper Less Camping
Almost
Yep...reason I gave up m '09 2500HD gasser, wasn't impressed with the 6.0 motor after pulling a 9500lb TT for a few years.
