Old 04-09-2015, 07:35 PM   #1
GLCM Warrior
Lefty59's Avatar
Dealer Hitch Install
When we bought our TV we had the dealer install the B&W Turnover Ball gooseneck hitch for us. We towed with it all last year, and this year when I went to remove the Companion 5th wheel hitch to do the annual inspection (and to help my daughter move), I found that the bolt that attaches the handle had fallen out. Guess that was lucky for us since when I got under the truck to reattach the handle I found this (see photos).
Today I took it back to the dealer & got them to put the washers in the proper place.
Out of the 16 attaching bolts used on the hitch, 10 were installed with the flat washer on the wrong side of the bolt.
We feel blessed that nothing bad happened while the bolts were installed improperly.
I have an annual hitch inspection on my list of preventative maintenance tasks but the importance of that inspection has certainly been emphasized by this experience.
Safe travels!
ID:	73661   Click image for larger version
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 04-09-2015, 09:16 PM   #2
cstover's Avatar
And another reason I like doing things myself. Besides the fact I know the ins and outs of my hitch, I know without a shadow of a doubt that my hitch is installed correctly.
cstover is offline   Reply With Quote
Old 04-09-2015, 09:23 PM   #3
fast murray's Avatar
When you see things like that it makes you wonder what else they do wrong. It seems there is no accountability or pride in workmanship most places.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 04-09-2015, 09:31 PM   #4
Common sense. Some dealers......
hockeyzebra27 is offline   Reply With Quote
Old 04-09-2015, 09:39 PM   #5
dcheatwood's Avatar
Wow! You're a blessed man. Hope you get it worked out.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is online now   Reply With Quote
Old 04-09-2015, 09:42 PM   #6
SCCS's Avatar
Should have two flat washers and a lock washer on each bolt.
SCCS
15 F150 xlt pulling
15 Forest River mini-lite 2502s
SCCS is offline   Reply With Quote
Old 04-09-2015, 09:51 PM   #7
Was always told to NEVER put a flat washer under a lock washer unless it was over a slot or on soft material as the flat washer could turn and defeat the lock washer's purpose.
Also in the picture, the bolt is a gr8 and should have hardened flat washers under the head of the bolt.
Old 04-09-2015, 09:56 PM   #8
Stormrider151's Avatar
If the guy that installed those bolts worked for NASA we never would have made to the platform.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 04-09-2015, 09:59 PM   #9
That's why he's a very questionable "RV Tech".
Old 04-10-2015, 10:43 AM   #10
GLCM Warrior
Lefty59's Avatar
Fixed
Here's how they are now after the dealer fix:
ID:	73754   Click image for larger version
2014 Wildcat 312QBX
dealer, hitch
