Old 02-09-2016, 09:10 PM   #31
Mark and Linda's Avatar
When we bought our trailer it was used, the dealer set up the hitch that came with the trailer, a ProSeries with SC built in. At the time the trailer was not loaded, I have finally gotten it to where I am comfortable with it. It takes some tweaking...as far as loading the trailer and adjusting.
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
Mark and Linda is offline   Reply With Quote
Old 03-01-2016, 10:10 AM   #32
wicked1's Avatar
They usually do, mine was so bad on my first Trailer 2012 Shasta Revere 27RLSS 6700 dry and hitch 900#'s that if I had not reset mine from scratch I would have stopped camping it was so bad to drive with. I have learned to measure, set, test and reset so well now, that our Anderson makes towing a dream. Never rely on the dealer especially when they throw in the wrong size hitch for free. I will use my Anderson until I go to a 5er
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2015 FR Rockwood Roo 23IKSS
wicked1 is online now   Reply With Quote
Old 03-03-2016, 06:52 PM   #33
I have a 2011 frontier sv cc and am considering selling my popup and going with a rockwood mini lite 2109s.do you ever feel underpowered? need more truck or less camper.
dave16509 is offline   Reply With Quote
Old 03-05-2016, 11:29 PM   #34
I have a 2306 and pull it with my '11 Frontier Pro4x crew cab. I don't have any problems with power. Just be sure to get an equalizer hitch. Also average around 11mpg when towing - which I consider to be good. Where will you mostly be towing?
Darren F.
TT: 2013 Rockwood Mini Lite 2306
TV: 2011 Nissan Frontier Pro-4x CC 4x4
Living it up w/the wife(Jenny), 2 year old daughter(Stella), & dogs(Remi and Riley)
FrontierRookie is offline   Reply With Quote
Old 03-06-2016, 11:09 AM   #35
I am pretty sure that my WDH (fastway e2) is setup wrong from the dealer.
Edit: yep, I'm 100% sure that it's wrong, unless the L-brackets are supposed to move!!
sgtSmokdU is offline   Reply With Quote
Old 03-06-2016, 04:47 PM   #36
mostly in the ny,oh pa area but i just retired and would like to visit southern states..way back in the late '70s and early '80s I was stationed at ft stewart and the ft rucker areas and I loved the locations.would like to visit those areas again.
Old 03-06-2016, 05:33 PM   #37
I think you'll be fine, honestly. I'm moving up to a Titan, but not for power reasons. It's for payload reasons. My tongue weight is also higher than the 2109s. I do really like the layout of the 2109s.
Darren F.
Old 03-13-2016, 05:26 PM   #38
updhaul's Avatar
sgt, if your brackets are moving on your trailer with the fastway e2 it is an indicator of problem, perhaps even loose bolts. or too tight bolts Check your manual and make sure they are positioned perpendicular to tt frame at the correct distance on both sides. It's common to realign and check proper tightness of bolts, don't overtighten as they can cause the "hanger-plates" to bow if over tightened.
Have a large torque wrench and sockets if you go further
I wish I had assembled my hitch from scratch before pdi with a little supervision.
updhaul is offline   Reply With Quote
Old 03-16-2016, 08:24 PM   #39
Both of the "hanger brackets" look bowed out like this. I'll dig out a torque wrench this weekend and do it properly.
Sent from my Nexus 6 using Tapatalk
Old 03-16-2016, 08:54 PM   #40
Too Tall's Avatar
So my question is this, (I have a husky weight distribution hitch with the round bars and the chains.) When you transfer weight from the tongue to the vehicle drive axle, are you also transferring weight back to the trailer axles? This is something I really don't want to do as my axle load is already where I want it. I have a 860 pounds of tongue weight which I can easily handle on the TV. I don't want to transfer any of that back to my trailer axle if possible.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
dealer
