Old 03-16-2016, 11:08 PM   #41
The link plates bend like that when over torqued. It looks like you are going to need new ones if they are all that bent.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 03-23-2016, 10:04 PM   #42
Platokidd's Avatar
Location: Home of the 2016 WORLD SERIES CHAMPIONS CHICAGO CUBS
Originally Posted by Too Tall View Post
So my question is this, (I have a husky weight distribution hitch with the round bars and the chains.) When you transfer weight from the tongue to the vehicle drive axle, are you also transferring weight back to the trailer axles? This is something I really don't want to do as my axle load is already where I want it. I have a 860 pounds of tongue weight which I can easily handle on the TV. I don't want to transfer any of that back to my trailer axle if possible.
The idea is to distribute the load of the trailer evenly to the entire tow vehicle and trailer wheels. ..
2014 LaCrosse 323RST-TE-C
2009 CHEVY 2500HD Silverado Z71
2016- 92 nights of camping
Old 03-23-2016, 10:23 PM   #43
Bluepill's Avatar
Excerpt:
A weight distribution system is important because it eases the situation by spreading some of that increased tongue weight off the rear axle of the tow vehicle and onto the front axle, as well as the axle (or axles) of the trailer. With that leverage, everything balances out and driving performance increases dramatically.
From Here:
Purpose of Towing Weight Distribution Systems - How Towing Weight Distribution Systems Work | HowStuffWorks
2008 Itasca Meridian 37H
Old 03-24-2016, 12:20 AM   #44
Too Tall's Avatar
Originally Posted by Bluepill View Post
Excerpt:
From Here:
Thanks, that's great info.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 03-24-2016, 02:42 PM   #45
Robs1968's Avatar
Originally Posted by dave16509 View Post
I have a 2011 frontier sv cc and am considering selling my popup and going with a rockwood mini lite 2109s.do you ever feel underpowered? need more truck or less camper.
We have a 2014 Frontier and tow a Roo 21DK with no problem
Robs1968 is offline   Reply With Quote
Old 05-30-2016, 05:02 PM   #46
Ambassador
Ken K.'s Avatar
I towed a 2502ks mini lite it grossed at 6500lbs with a v6 Tacoma. I used a Equalizer II with 1200 lb trunnions. I towed it 375 to 400 miles one way with no issues other than frequent stops for fuel. I also had to adjust the WDH after installation. That first trip was a white knuckler for sure. After making adjustments it was completely different. I will never ever trust someone else to set up my rig again. You drive it, it's your responsibility to make sure it's roadworthy.
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2015 Rockwood Mini Lite 2502KS
Ken K. is offline   Reply With Quote
Old 06-21-2016, 02:27 PM   #47
The more I read the more i am sure mine is not set up as well. I have a 2017 grey wolf and about flattened the right side drag bar. Plenty of truck to pull it but I think the way they set it up I was hanging low in the back for sure. Great thread here. Look forward to more comments.
akhenaton22 is offline   Reply With Quote
Old 06-21-2016, 10:07 PM   #48
Too Tall's Avatar
It definitely can be a challenge to get it right. The key for me was getting enough drop to level the trailer. I've got it now however. You can see my camper and truck in this short video that it's level. I'm a little heavy on the rear of the truck but can't go down anymore on the shank. IMO, it's just about perfect. Skip forward to my truck. https://youtu.be/lQZELcg6B-A
USMC 68 -70
Old 08-05-2016, 09:27 AM   #49
Thank you all for the great info posted here. I'm going through some of the same issues and have found a lot of great info in these threads. We went from a 29BH with one slide to a 32 BHDS that is easily a foot taller and 1,000 lb heavier. Dealer set up the hitch and kid looked about 20. "Yep looks level". With the 29 I really barely knew it was back there. With the 32, it was white knuckle until I raised the Equalizer L bracket one notch. Now it's more stable but the nose of the TT sits up a little, which I think is why I now get a push from cars passing me while before it was just trucks and wind. I'm looking for a scale but in the meantime I'm going to measure everything per the instruction book and probably lower my ball one notch. EQ bars aren't perpendicular with trailer frame either. So, moral is as many have stated, get to know your hitch sooner rather than later and do it yourself.
Thanks to all who have posted previously.
2008 2500 Suburban
2016 Surveyor 32 BHDS
fiveweight is offline   Reply With Quote
Old 08-06-2016, 07:38 AM   #50
Coachman 312BHDS
I went through this exact same scenario with the initial dealer WDH setup. If there is a negative to raising the L-brackets- it is putting the sway bars on higher but do it anyways. I use an extra couple of 2x6's under the bottom of the electric jack to help raise it a bit higher. It is a relaxing drive/tow now. Solid tracking and zero sway.
2016 Coachmen Freedom Express Liberty Edition 312BHDS (37')
2014 F150 Lariat 3.5 V6 Eco Screw max tow - Century hard cap - Husky Centerline TS WDH
tbln930 is offline   Reply With Quote
dealer
