Old 06-09-2016, 08:56 AM   #1
Adony's Avatar
Decision on New Shock Absorbers
I recently purchased a 2006 F-250 to replace my previous tow vehicle. It has one factory shock that shows signs of leaking and needs to be replaced. Will replace all 4 at same time. Is it worth the extra $$ to replace them with Bilsteins 4600's or KYB's instead of lower cost Monroe Gas Magnums? Just seeking opinions or actual experience comments..
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 06-09-2016, 09:02 AM   #2
Jim34RL's Avatar
When my stock shocks go out or at 100,000 miles which every comes first I am replacing them with Bilstein 4600 series shocks, for my Ram. These come highly recommend by other truck users on Turbo Diesel Register. com website.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 06-09-2016, 11:13 AM   #3
Happy with my 4600's.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-09-2016, 11:55 AM   #4
Monroe Reflex have worked well for me. Slightly softer ride than magnums when unloaded.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 06-09-2016, 12:27 PM   #5
thebrakeman's Avatar
I think the Reflex units are a slight upgrade for load capacity, compared to standard Monroe (Sensatrac, etc).
KYB are good quality OEM replacements, but I don't think they are intended to be an upgrade.
thebrakeman is offline   Reply With Quote
Old 06-09-2016, 12:36 PM   #6
I go RV'ing not Camping
jgourlie's Avatar
I have always used Bilsteins
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 06-09-2016, 02:33 PM   #7
Wanna Be Camper
SaskCampers's Avatar
Just put Monroe Reflex's on my 250 to replace the junk factory Rancho shocks. The truck rides much better, I would recommend these to anyone who is not planning on using their truck for offroading. Then whatever style shock is fine. FYI if you check on numerous forums, a number of people have difficulty getting warranty on Bilstein shocks.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 06-10-2016, 12:07 PM   #8
I put the Monroe Load Adjusting Shock on my '03 1500 RAM in the rear, the front are straight Monroe SensaTrac, now called magnum I think.
That's the coil over shocks. Love the handling and ride when loaded, even from the home center, but empty it gets bumpy on uneven pavement, but not that it is uncomfortable, but you know it's bouncing back there.
2500+ miles camping 2015:Black Hills, Sioux Falls, Lake Superior North Shore, MN State Parks
2003 Dodge Ram 1500 HEMI 5.7 / 3.92 - 2004 Coachmen Spirit of America 248TBG
davidx2000 is offline   Reply With Quote
Old 06-10-2016, 12:21 PM   #9
NMWildcat's Avatar
Bilsteins are the only way to go in my mind. I've found the best prices at Learn About Bilstein Shocks - Shockwarehouse.com. I have used bilsteins on my last 4 tow vehicles and have had excellent results. My brother buys Monroes and has replaced several due to failure. Just my experience..
Spend the little bit extra to get the best
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 06-10-2016, 12:28 PM   #10
jhoppmann's Avatar
I replaced the factory "Rancho" shocks (really are Ford shocks with a Rancho sticker) on my 2012 F250 with Bilstein 5100's. They are a firm riding shock, but definitely got rid of the chatter and bounce I had with the worn out factory shocks. I ordered them online from Shockwarehouse. Looks like the 4600 and 5100 are similarly priced there.
I had Bilstein 4600's on a 2002 Dakota, and then 5150's on a 2010 Tacoma prior to the F250. Nothing bad to say about any of them.
2015 Rockwood Mini-Lite 2306
2012 F-250 FX4 6.7 diesel
10k Equalizer Hitch
jhoppmann is offline   Reply With Quote
