Old 01-08-2016, 03:58 PM   #11
Fulltime family RVer
btw, thanks for asking this. I'd like to install a dash cam myself.
ependydad is online now   Reply With Quote
Old 01-08-2016, 08:58 PM   #12
Usually Confused Member
emm-dee's Avatar
Here's a pix of my dash cam install in the Ram. Wires are completely hidden until they come out of the headliner to attach to the cam. The cam is mounted slightly right of and in front of the rear view mirror (to comply with a strong "suggestion" by a highway patrol officer who said mounting it within the line of sight of the driver is not acceptable. Where it's located now means I can't even see it while driving.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 01-08-2016, 09:26 PM   #13
Kenny kustom's Avatar
That's where I plan to put mine.
I had it down low on the Ford, annoyed me more than anything, seeing the screen.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 01-09-2016, 05:58 AM   #14
Todouble's Avatar
So I gotta ask? What's the purpose of having these dash cams?
Todouble is offline   Reply With Quote
Old 01-09-2016, 07:03 AM   #15
Idiots.....
Also, when you film said idiots, you put it on YouTube!
2016 Sabre 36QBOK
Old 01-09-2016, 08:59 AM   #16
Todouble's Avatar
Gotcha! That's what I thought but was thinking there was another reason.
Old 01-09-2016, 10:14 AM   #17
Jim34RL's Avatar
Originally Posted by Red Wolf View Post
Unfortunately, the fuses are in the engine compartment next to the driver side battery in the new rigs. I was going to do this, until I found the fuses were no longer by the driver's door!
-Red
Big Bad Wolf - '02 Dodge Ram 2500HD 5.9 CTD / Prodigy / Putnam Class V / Reese 15k Pro
Wolf Den 3 - '14 Rockwood Signature Ultra Light 8280WS
Since you are a member of TDR contact Geno's Garage for help on your wiring issues. I do not know about the fourth gens that much and the use of the BCM ( Body Control Module ) on the truck now. But on the Third Gen trucks with the TIPM (Total Integrated Power Module) it was very easy to destroy the TIPM by adding additional electrical components to the vehicle. Replacement cost for the TIPM the last I check are will north of $700 + labor.
For less than $80.00 you can save a very expensive trip to the dealer for a replacement of the BCM, if this is like the old TIPM on the third gen trucks.
Just my advice.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 01-09-2016, 10:24 AM   #18
For free, you can tap into the power point.
For anything other than a camera or tpms monitor power, I would run a dedicated fuse box.
But, those two draw so, so little.
2016 Sabre 36QBOK
Old 01-09-2016, 10:52 AM   #19
Jim34RL's Avatar
2016 Sabre 36QBOK
Kenny, I know of guys who have replaced their third brake light with LED's lights and burn out the TIPM. They have also used RECON HID lights and have had issues to.
The Ram uses a CANBUS system and several components are communicating within the same wiring circuit. As small as a .5 Volt difference will cause an issue some times. The TIPM on the third gens is the central module that gets feed back from the components and if the voltage is incorrect it will trip. After tripping and being reset for three times it goes by, by and you need to buy a new one. The TIPM will automatically reset so by time you catch the issue you are buying a new one.
Just saying
Jim W.
Old 01-09-2016, 11:24 AM   #20
Dedicated accessory power in a '15 RAM 2500?
Ok, but changing a lamp on the can bus will cause problems.
What's the purpose of a power point?
To supply current up to the fuses capacity.
No different hard wiring the camera, or plugging it into the socket.
Lamp replacement and tapping into the power point, completely different.
2016 Sabre 36QBOK
500, cat, power
