Old 05-26-2016, 10:22 PM   #11
Thunderbolt75's Avatar
I haven't had to fill my DEF tank yet. Just turned 91,000 miles on the clock. 😉
Sent from my secret hardened bunker.
Be safe, but if you cannot, be violent.
Choose to be a winner, not a victim.
Thunderbolt75 is offline   Reply With Quote
Old 05-27-2016, 09:14 AM   #12
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
DocGTO is offline   Reply With Quote
Old 05-27-2016, 09:16 AM   #13
Originally Posted by retiredcamper47 View Post
I push the "setup" button on the steering wheel and it goes thru it's paces.
Shows oil ok, etc, and shows DEF level ok. Wish it would show 1/4, 1/2, 3/4 level for the DEF. Guess it would give a message when you need to add DEF.
Haven't experienced it yet.
Bob
Only trhe Dodge has a nice DEF gauge.
I use my Edge CTS digital gauges and it shows me % on the DEF tank whoch is much better then the "ok" crap I get until it is at 20% or a miles countdown.
Doc
Old 05-27-2016, 11:45 AM   #14
Ford's probably cheating. My TDI. Never needs DEF
Blest with a Coachmen Prism 24G
I Simpson is offline   Reply With Quote
Old 05-27-2016, 03:59 PM   #15
mike.t's Avatar
Ram comes with a DE gauge no more wondering for me
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 05-27-2016, 04:33 PM   #16
Forbes's Avatar
Our 2015 F350 has a warning come up on screen at 500 miles left on DEF. have gotten in habit of filling it about every 5 or 6 tanks when I pull into Pilot / Flying J if under toe, takes maybe a gallon. Just never really keep check on it one of those things you got do just like buying fuel.
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
2014 F350 / 2015 CC 36 CKTS
Days Camping 2014-96, 2015-130, 2016-126, 2017-42 and counting
Forbes is offline   Reply With Quote
Old 05-27-2016, 09:20 PM   #17
Gonetothedogs's Avatar
DEF Refill or Not
Refilling the DEF tank will depend upon whether you have selected Normal or Towing. You will go through DEF quicker if you are towing your RV than if you are driving under "Normal" conditions. In the Ford F-350, you will get warnings starting at 500 miles to go. Once you get down to empty, the truck will go into what some refer to as the "limp" mode (< 55 MPH). I recently was faced with a failed DEF Sensor C. I decided to have the entire DEF system removed and done away with. No more messing with DEF, no more warnings, or other such problems. There is an expense involved with this type of modification, but no longer have to worry about filling or paying for it. A good Diesel shop can do the modification in a day.
Mac & Joyce
___________________
2012 Ford F-350 Lariat DRW
2015 Sanibel 3901
OK-3 Wire...Living the dream
Gonetothedogs is offline   Reply With Quote
Old 05-27-2016, 09:53 PM   #18
mike.t's Avatar
Wonderful however most of us don't tow with a Yugo.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 05-27-2016, 09:57 PM   #19
mike.t's Avatar
Great I am sure your grand children will thank you for the clean air you left for them and theirs!!
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 06-01-2016, 06:05 AM   #20
Towing will cause for the more consumption of the DEF fluid as the exhaust filter will need to be cleaned more for fuel requirements due to load. Also you can look at menu to see how much fluid you have. Don't run it out! Will cause loss of reduced power and then tennis shoe mode.
jimmyt11664 is offline   Reply With Quote
2012, ford
