Old 05-26-2016, 03:48 PM   #1
fireman1317's Avatar
DEF in a 2012 Ford 6.7l
So I have had my truck for just shy of 2 months and have put on just shy of 2,000 miles. I have filled the truck 3 and 1/2 times now and have the 37gal tank. Assuming the DEF tank was full when I bought it, should it not be getting close to needing to add DEF? I have not seen a dummy light come on yet. Just unsure.
2016 Vibe Extreme-Lite 315BHK
2012 F350 CCSRW 6.7l 4x4 LB
Nights camped in 2016: 26
Nights camped in 2017: ?
fireman1317 is offline   Reply With Quote
Old 05-26-2016, 03:51 PM   #2
jhoppmann's Avatar
Originally Posted by fireman1317 View Post
So I have had my truck for just shy of 2 months and have put on just shy of 2,000 miles. I have filled the truck 3 and 1/2 times now and have the 37gal tank. Assuming the DEF tank was full when I bought it, should it not be getting close to needing to add DEF? I have not seen a dummy light come on yet. Just unsure.Sent from my iPhone using Tapatalk
I got a 2012 last June and put on 8,000 mi and have only had to refill once
2015 Rockwood Mini-Lite 2306
2012 F-250 FX4 6.7 diesel
10k Equalizer Hitch
jhoppmann is offline   Reply With Quote
Old 05-26-2016, 03:53 PM   #3
Ok. That makes me feel a lot better. Thanks
Old 05-26-2016, 04:03 PM   #4
I have a 2011 F250 longbed RWD diesel and I don't have to refill the DEF unless I tow a lot. I use 2 and one half gallons per 8,000 miles unless towing most of the time and then about 2 and 1/2 gallons per 4,000 miles.
whj77372 is offline   Reply With Quote
Old 05-26-2016, 04:43 PM   #5
The average interval on the newer trucks is about 5K miles per tank. You will get a warning when it is low. No big deal at all to top off.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
DocGTO is offline   Reply With Quote
Old 05-26-2016, 04:55 PM   #6
Toothpick's Avatar
Top off at the pump at a truck stop. It's a lot cheaper.
$15 for 2.5 gal at Autozone.
I filled up at Pilot 4.5 gals for 11.72.
2016 FR Vengeance 25V Toy Hauler
2015 Ram 2500HD CC 4x4 6.7L Cummins
2017 Indian Chieftain Darkhorse
2017 Indian Scout
Toothpick is offline   Reply With Quote
Old 05-26-2016, 05:48 PM   #7
I'm putting in 2.5 gallons every 2,500 to 3,000 miles.
I'm using nothing but the best, Supertech DEF for $7.88 for 2.5 gallons available from Walfart.
Skyliner is offline   Reply With Quote
Old 05-26-2016, 07:38 PM   #8
I push the "setup" button on the steering wheel and it goes thru it's paces.
Shows oil ok, etc, and shows DEF level ok. Wish it would show 1/4, 1/2, 3/4 level for the DEF. Guess it would give a message when you need to add DEF.
Haven't experienced it yet.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 05-26-2016, 07:47 PM   #9
Wait until it says you have about 250 miles to empty. It doesn't like to be filled when it is not almost empty. I like to go to truck stops and use the DEF pump. That way, you can fill it without over filling.
2012 CC 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 05-26-2016, 10:15 PM   #10
Kenny kustom's Avatar
Consumption depends on driving habits and towing..
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
2012, ford
