Old 05-30-2016, 09:21 AM   #1
talldiver's Avatar
Demco 18k Autoslider Problem
I am using the Demco 18k Autoslider on 2015 F350 diesel. Worked great for the first 20 or so hitch ups but it started giving problems on our last trip. For whatever reason the jaws will not snap close. Spent 20 minutes on the phone with Demco tech support and they could not find the problem. The jaws eventually lock but it takes 10-15 attempts.
The tech said the new Lippert pin box might be causing the problem and will require the jaws to be reground
I can close the jaws manually and everything is greased according to the manual.
Anyone else using Demco experiencing the same problem?
2015 F350 SRW 6.7 PSD
2016 38FB2 CC
Andersen Hitch
talldiver is offline   Reply With Quote
Old 05-30-2016, 09:31 PM   #2
We had The same issue today. We spent about 40 minutes trying to hook up without the jaws closing. Once they did close we had no idea why they closed versus the other 30 times we tried to hook up.
Why are they saying the jaws may need to be re-ground? Sounds a little strange
Sent from my iPad using Tapatalk
Bluewrx272 is offline   Reply With Quote
Old 05-30-2016, 09:43 PM   #3
Had the same issue last year. Tried several times to hitch up and jaws would not close. After closer examination one side of the truck was higher than the other do to slope of ground. Adjusted my approach and was successful. These hitches can be timid at times. I don't know if i would agree with Demco that the answer is regrind the hitch.
Kevin & Denise Griffin
2015 Ford F350 Super Duty 6.7 Diesel CC SB, Demco 18K Hijacker Auto Slide, Pace Edwards Electric Tonneau, TST TPMS 507 Standard Sensors, Titan 50 Gallon Midship Fuel Tank
2016 Prime Time Crusader 315RST 5th Wheel, Dometic Slide Toppers
KEG_75 is offline   Reply With Quote
Old 05-30-2016, 10:28 PM   #4
We did notice that one side of the truck was a little lower than the other an that may have been our issue as well. Thanks for your help.
Old 05-31-2016, 02:09 PM   #5
My autoslide can be a little picky at times about angle. Never as bad as what you have described. I found that this hitch is fairly picky about height. The couple times I have had issues getting it to close, I dropped the trailer a little bit and made it ride up the ramp by about 1/4". That seemed to fix it. Also have noticed that these things don't like to engage gently. Not saying to slam it backwards, but I let mine engage with a good solid thunk.
rmoore0852 is offline   Reply With Quote
Old 05-31-2016, 11:05 PM   #6
Demco hitch
I love my Demco auto slide.
When mine doesn't snap shut it is usually the height of the pin box.
I try and look at the jaws and pin and
See if it needs lowered or raised to connect.
If the slide plate is about 1/4" above the hitch it will go right in.
alayton is offline   Reply With Quote
Old 06-01-2016, 07:04 AM   #7
talldiver's Avatar
Thanks for the ideas. I will try them next time I have a problem
2016 38FB2 CC
Andersen Hitch
Old 07-09-2016, 04:20 PM   #8
Jimsue's Avatar
I have been experiencing the same issue with my Demco Autoslider. Just got back from a 3 month trip and about half the time the jaws would not engage until about 10 attempts at various heights and angles . One time it was so bad I had to ask a Good Samaritan with a " traditional" Reese to hook up my 5ver and pull it from the site to completely level ground so I could hook it up to my Demco. Embarrassing, frustrating , and not a little disappointing!
I plan on contacting Demco yet again to see if they have come up with any more suggestions...
2015 F350 Lariat Crewcab DPS SWD 4x4
2013 Sabre BKOK 31
andersen ultimate 5th wheel hitch
Renogy Solar Suitcase
Progressive Industries EMS
Sea Eagle 420 Tandem Inflatable Kayak
Jimsue is offline   Reply With Quote
Old 07-14-2016, 08:20 PM   #9
Jimsue's Avatar
Hey all...
Spoke to Troy Woelber at Demco. He informed me that the company is aware of a problem with the jaws not locking on some of the Hijacker models and he encourages anyone having similar issue to contact him at : (800) 543-3626 ext 157
In my case, Demco is shipping me a new set of locking jaws ( no charge) to replace the original one.
Please encourage anyone you know who has this problem ( jaws not engaging ) to contact him. He was very patient, thorough and helpful. I will keep everyone updated on how the new mechanism works .
2013 Sabre BKOK 31
Old 07-14-2016, 08:46 PM   #10
JohnF's Avatar
When you say your jaws are not engaging, I assume you mean that you can not put the safety pin in the handle. In other words the handle bar does not go far enough to put the pin in. Correct? That is the problem I have. Instead of keep trying to get it to happen, I have a smaller diameter pin that will fit into the hole. I have always found that if I pull forward a few hundred feet the handle always seems to set properly and I get out and remove my temporary pin and put the larger size one in.
John
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
slide
