Old 08-31-2012, 04:57 PM   #31
Hi, Just got back from the Dealer with my TT.
I brought my bathroom scale and I weighted the tongue with a lever that gave me 1:4 ratio, tested it with myself and some objects and it was surprisingly accurate.
So after weight it like 10 times at the dealership with diffrent angle and then at my home in the street, i had about 145-158lbs on the scale never reaching 160. So approx 580-630lbs of Tongue Weight. My max allowed with WD kit is 700lbs. So its a pass! My sherline tongue scale is in the mail.....
Next I drove it for about 40 miles with cross winds of approx 30-35mph, I only felt a tiny bit of sway one in a while, nothing much. I only have one friction anti-sway on the left side only, and I wasent much tightned. So ill play with it and or buy another one next spring. I could seriously drive my truck with only my thumb and index with my right hand resting on my lap. (I dont plan on driving like that with my TT, was just used as a reference)
Next I went on the gouvernment semi truck scale truck only with full tank of gas and me 3140kg -> 6900lbs my GVWR is 8600lbs.
Truck with TT hooked = 5560kg -> 12232 lbs so with my GF plus some other stuff 12500 MAX and our GCWR is 13500lbs. Which gives me about 1000lbs more stuff to bring. Not gonna be the case here, I like to travel light. I had some water putted in the TT by the dealer, so i wasent dry of water but dry of luggage....
I know a 122'' wheelbase vehicule that tow a 33' TT is not the greatest on paper but the fact that my truck is more heavy that my TT is a plus imo.
All my tow specs are a PASS and im happy with it. Reseted the fuel used and fuel economy reading and got about 10mpg not too shaby.
Trans temps are gonna be easy to monitor i have a analog trans temp gauge factory.
Here is some pictures
Tongue weight aprox measurement,
Tongue weight setup
WD KIT
How its looks
ID:	18954   Click image for larger version
ID:	18955   Click image for larger version
ID:	18956   Click image for larger version
ID:	18957   Click image for larger version
2007 Hummer H2
2012 Surveyor SP-293
1984 Camaro Z-28
2012 Polaris RZR XP-900
Ricard350 is offline   Reply With Quote
Old 08-31-2012, 04:58 PM   #32
Talk to u guys later im going to go and try some slopes....
laters
2007 Hummer H2
1984 Camaro Z-28
Old 08-31-2012, 05:00 PM   #33
Herk7769's Avatar
You might want to see what the tongue weight is with your gear and food and stuff in it. Unless you plan on towing it empty?
Most likely you will be limited to about 700 pounds of gear in the camper.
It sounds like a lot, but you will find it fills up quickly.
HAM CALLSIGN - KC3FFW
Old 08-31-2012, 06:12 PM   #34
Triguy's Avatar
Ricard,
I give you credit for working up your dry weight numbers and I second Lou's suggestion to weigh the tongue again once you are loaded. I find that I can be +- 75lbs depending how I load the camper and I have a moderately lightweight camper, too.
You'll like that Sherline. I have a 2000lb Sherline and use it several times a year and whenever I decide to experiement on loading. I've found with several campers that there is a difference in the towing experience depending how I load. This is all personal and depends both on the combination of TV and TT and how I load. Good luck with everything.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-31-2012, 06:34 PM   #35
Thanks for the follow up. Looks like you'll be OK if you watch your weight and take it easy. Cinch up that sway control, and remember you can never back up with that thing attached.
crasher is offline   Reply With Quote
