Old 02-24-2011, 02:36 PM   #1
Did I pick the wrong tow vehicle?
Iíve read the forums over and over again and thought I knew how to figure out what I can tow.
I am looking to move up to a 5th wheel, but want to know what would be a safe range for my truck.
I used the online calculators and if I understand my numbers, Iíve come up with a hitch weight max of no more than 1400 lbs and a trail weight of no more than 8900lbs.
I was hoping my 2010 F250 6.4L 4x4 3:55 Short bed can tow more, so I am hoping you can tell me if I am looking at it correctly.
Here are my numbers from the door:
GCWR=23000
GVWR=10000
Front GAWR=5600
Rear GAWR=6100
Actual:
Gross weight= 8632 lbs (me, wife, full tank)
Actual Front= 5140
Actual Rear= 3492
I am looking at a couple of 5th wheels that have dry hitch weights in the 1400ís lbs and in the 1900ís lbs.
The dry weights are 9500lbs and 10900 lbs respectively. They are between 32-36í in length.
We will not be in the Rockies or anywhere that challenging.
We are usually no more than 200 miles from home with the Smokeyís as the hurdle to get over, but only 2 times a year.
Should I forget a 5th wheel and stay with a travel trailer?
Thanks for any input!
buckeyefan is offline   Reply With Quote
Old 02-24-2011, 03:52 PM   #2
MtnGuy's Avatar
Wow, that is 1 heavy truck. Are you sure you have the correct figures on your actual weight with you, the missus, and a full tank of gas ??? I didn't even know truck scales could could weigh down to the pound increments........mostly it is 20 lb. increments.
By those figures you can put 2600 more pounds on the rear axle, so you have some leeway with the hitch weights there. The GCWR should be OK with a 10,000 trailer. But the total GVWR is going to be the show stopper......by the numbers you have posted you can only add 1368 lbs. to the truck, ie hitch weight.
What cab configuration do you have ??
Old 02-24-2011, 03:53 PM   #3
Oakman's Avatar
Are you sure the scale where you weighed your truck is correct? My 2010 F250 Crew Cab 4X4 and 6.4 liter diesel comes in at 8160 lbs. with me, a full tank of fuel and a slider hitch in the bed. My truck was weighed on a CAT scale that guarantees the weight.
I know one other person who has the same truck only a 2008, his weights are:
Front axle 4940
Rear axle 3220
That inlcudes him, his wife, a full tank and the hitch in the bed.
I've seen plenty of people towing some really heavy trailers with these F250 Fords. However, if it were me, I'd try go with a fifth wheel with a dry weight at 10,000 lbs. or less.
BTW, my Wildcat has a listed hitch weight in their brochure of 1610 lbs. and I'm sure with all the "stuff" I've put in the trailer the pin weight is probably around 1800 lbs. My truck barely knows it back there.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 02-24-2011, 03:59 PM   #4
MtnGuy's Avatar
Looks like Oakman and I are on the same page, about a minute apart.
Old 02-24-2011, 04:14 PM   #5
First look at Ford's towing guides. They usually state towing specs. As "dry" weights are not real life, I suggest you use 18-20% of the trailers GVW as what the pin weight will be for payload purposes.
bailer6334 is offline   Reply With Quote
Old 02-24-2011, 04:24 PM   #6
Grape Escape
There are many 5th wheels you can pull with ease. Go for it. You won't be sorry.
By the way check my signature. More than happy and satisfied with towing the 5r
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 02-24-2011, 06:43 PM   #7
You will be over GVWR with either trailer so get the one you want. The truck should handle either one just fine.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 02-25-2011, 08:29 AM   #8
Oakman's Avatar
LOL, apparently you're faster on the keyboard than me.
Bob and Joyce
ATU Local 788
Old 02-25-2011, 06:31 PM   #9
Sgt. Schultz's Avatar
Ford has a suggested max of 15K for your setup --https://www.fleet.ford.com/showroom/rv_trailer_towing/2010/SuperDutyFifthWheel.pdf
It looks like you have 2600+ for usable RAW so it may be just be balancing of the load that will allow you to get to that 15k 5er
PT Avenger 33BHS-TE
GMC 2500HD SLE 4x4 Crew Cab 6.0 with 4.10's
Sgt. Schultz is offline   Reply With Quote
Old 02-26-2011, 07:12 AM   #10
Toy-aholic
that 3:55 gear ratio would concern me the most
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
