Old 05-06-2015, 09:27 AM   #1
CampinDad's Avatar
Did my dealer short me on my hitch?
I just picked up a new TH TT last week and was so worried about how to hook up/remove the WDH that I didn't pay attention to what they gave me.
Here's my set up:
2015 F250 6.7L pulling a 2016 Keystone (sorry! We loved our HW276, but needed more room) Carbon 33 with ship weight of 9000#, hitch weight of 1300# and carrying capacity of 4000#.
I have a 10,000# e2 round bar hitch right now, which looks to be fine as long as I keep the camper empty.
My set up is level, but I noticed some bouncing/bucking while driving. Seemed like the camper was see-sawing some.
Should I go back to the dealer for a different hitch?
CampinDad is offline   Reply With Quote
Old 05-06-2015, 09:34 AM   #2
TURBS's Avatar
Hey no reason you can't hang with us even tho you own a s.o.b
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "4 nights"
Old 05-06-2015, 09:35 AM   #3
CampinDad's Avatar
Here are the weights I got I the way home (though I'm not sure I did it right):
Truck only: Click image for larger version
Truck and camper: Click image for larger version
Camper only: Click image for larger version
ID:	76280   Click image for larger version
ID:	76281   Click image for larger version
Old 05-06-2015, 09:48 AM   #4
vinmaker's Avatar
What? You sold your High Wall? NOoooooooo.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 05-06-2015, 09:49 AM   #5
CampinDad's Avatar
Well, traded it in. Good luck on your sale though - I e been checking on your listing.
Old 05-06-2015, 10:00 AM   #6
Being a Round Bar sounds like it is W/D Only! With a Unit that Heavy what are you using for Sway Control? When loaded you will be over your Bar#? Youroo!!
Old 05-06-2015, 10:01 AM   #7
CampinDad's Avatar
Round bar with the L brackets instead of chains. Apparently helps with sway control as well as WD.
Old 05-06-2015, 10:08 AM   #8
Dave_Monica's Avatar
Unfortunately, it doesn't look like you did the weigh-in properly. When you weigh the truck alone, it has to be unhooked from the camper and preferably positioned so that you get a front and rear axle weight. It's suggested that you also weigh the set-up with the W/D disconnected and again connected. For these weighings, the truck's positioned on the front 2 plates to get front/rear axle weights and the camper axles on the 3rd plate.
If your hitch is rated for 10000#, the spring bars are most likely 1000# which I think are too low for your anticipated loaded tongue weight...hitch should be 1200/12000# or 1400/14000#.
Dave
Old 05-06-2015, 10:26 AM   #9
This is the problem with these dealers. They seem to have the 1000/10000 lb WDH in stock and use them on everything. That is what they gave me on my 3500 lb trailer. In your case I can see you being over on the WD bars and on the hitch weight. They should have given you the 1400/14000 setup. I also would want the equalizer (4 point sway control) not the E2 (2 point sway control) for a trailer that big.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 05-06-2015, 10:34 AM   #10
thebrakeman's Avatar
Sounds like he was towing this home new/empty. So it's reasonable to assume that it does not weight much more than the 9000lb ship weight from the sticker, which he stated. 8000 lbs on the axles, plus TW...sounds about right.
Yeah, 1000 lbs bars are not enough. You are probably right there (see above calculation), and it's already porpoising. Classic reaction when you are at or near the springbar rating. Same thing happened to us when we used a 400 lb Single Bar WDH to tow our old 3000 lb camper (375lbs TW).
Also, the E2 is not going to be as good for sway control, compared to the full-blown 4-point Equal-I-zer.
By the time you load this beast, you will likely be at or over 1100 lbs TW. That's actually too close to 1200 to me. I'd go with a 1400 lbs Equal-I-zer 4pt sway control hitch kit.
thebrakeman is offline   Reply With Quote
dealer, hitch
