02-29-2016, 02:23 PM
#21
Where we live never put any additive in any of my diesels... The engines have always out lived the rest of the truck..........
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
03-02-2016, 03:18 PM
#22
Originally Posted by pwrstroke2012
I can see adding lubricant for the older pre ULSD but wouldn't they design the newer diesels that require ULSD to run on it without lubricants? Just a thought. I have never added any to mine.
Originally Posted by Crusadernoob
The big problem is the HPFP is not a quality piece, they can't take any type of contamination, water, gas. It is not that they aren't designed for pressure, they can't take any contaminants run through them, the U.S. has low quality diesel.
Yep! The newer fuel is crap compared to the older pre 2007 blends and the newer style injectors are much more sensitive to contaminants, ect.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
03-04-2016, 11:27 PM
#23
If you are buying quality fuel from a reputable supplier there is no need to run or use any type of fuel additive. I have run many of the newer diesel trucks as I average 60k plus miles a year. My current 2015 has not had any issues at all even in Northern winters. Most fuel system issues arise from contaminates and "other products" added to fuel system. This is even true in off highway applications that are out now as well which I deal with everyday.
03-05-2016, 12:12 AM
#24
I have a 2013 F-350. If I recall, the diesel supplement states additives are not necessary. I would hate to have a failure and have Ford blame it on an additive & possibly void the warranty.
Just say'n
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
03-05-2016, 07:01 AM
#25
Just say'n
The diesel supplement does say you can use additives. Either a cetane booster or anti-gel if needed, and to use a Motorcraft product or equivalent.
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
03-05-2016, 07:09 AM
#26
I'll offer my .02 as a diesel mechanic/fleet manager for almost 30 years. Fuel quality and truck use varies greatly. We run Stanadyne fuel treatment and Motorcraft cetane booster. Their are other reputable brands. I've seen enough stuck turbos, injectors and clogged egr systems to know they help. Big rigs don't work like city trucks and if your fortunate enough to get a new truck every four years you can get by without them.
03-05-2016, 10:26 AM
#27
Originally Posted by Kenny kustom
Not a drop of snake oil here!
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Kenny, your truck and engine is not a Ford they need it!
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
03-05-2016, 10:29 AM
#28
that would be funny IF Ford didn't make their own diesel and Ram did
03-05-2016, 11:24 AM
#29
Ford was much better off with the combine engines.
2016 Sabre 36QBOK
2017 Dynamax Isata 4
03-06-2016, 09:53 AM
#30
The only reason I purchased the Ram was that the engine was manufactured by Cummins. It was either a Cummins or a Caterpillar diesel engine I was looking for. But in no way shape or form would I every purchase a IH (early Powerstroke) Ford, IVECO and or Duramax diesel engine. I have spent forty + years in the engineering/designing business with heavy equipment, so I know what engine to use and not to use for reliability.
Jim W.
03-06-2016, 11:51 AM
#31
Opti-Lube
1953 Ford NAA Jubilee
2015 Kawasaki Versys 1000 LT
2016 Ram 2500 Cummins, Crew, Longbed, 4x4
03-06-2016, 07:27 PM
#32
The Cummins is a FANTASTIC motor!!! It's everything else around it that is the problem...
2015 F350 6.7 Platinum
2015 Coachmen 360IBL
03-06-2016, 11:18 PM
#33
What blwnsmoke said....
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
03-07-2016, 09:36 AM
#34
Power Service. They make a full line of diesel fuel products. Been in business since trucking company1957. Family owned. Back in late 80's early 90's I was fleet mgr. for a small trucking company and we used Power Service to take care of our fuel related problems. NOT SMAKE OIL like some diesel fuel additives.
_____________
MK Clark
03-08-2016, 08:59 AM
#35
Ditto, I purchased the Cummins, the Dodge came with it.......
George Scott
2015 Salem Hemisphere Lite 272RLIS
2006 Heartland BH 3400/Summer Home
2021 Sabre 37FBT
