Old 03-12-2012, 08:53 AM   #11
I now have 11000 miles on my truck and it has used approximately 15 gallons of DEF. I do not see a drop in power or fuel mileage when it goes into cleaning. I guess it will be with us until something else is developed.
2011 F350 Lariat Ultimate Dually 6.7 w/ B&W Companion
2014 Heritage Glen 356QBQ
2016 Explorer Platinum, 1998 Mustang
1SG(Ret) (1987) US Army Aviation
Days/Nights Camped 2016: 34
dogwood36322 is offline   Reply With Quote
Old 03-12-2012, 07:15 PM   #12
Coops1's Avatar
I'm at just over 5000 miles and still on the first 5 gallon's of urea. I think GM had one or two recalls to re-flash the system (software update) early on and from what I've read on other forums there hasn't been much problems since. I think/hope this is a moot point and I have no problems in the long run but like someone else has said urea is not a new concept. In my opinion it shouldn't hold you back from upgrading your truck... If you like what you have now you'll love the new one.
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 03-12-2012, 07:45 PM   #13
transamz9's Avatar
IDK that I would say that.......I don't think you can get 19-20 MPG everyday out of any of the new Diesels and I don't have to buy the DEF fluid either. You want to talk power? I spent $1500 and you won't touch the power I have with any of the new one unless you do away with all that junk. The jets that our so call leaders ride in put out more emissions that all of the light duty diesel truck put out together in one year. They need to leave us alone and worry about the more important stuff , like getting our brothers home and feeding our hungry not everybody elses.
transamz9 is offline   Reply With Quote
Old 03-12-2012, 07:53 PM   #14
RattVader's Avatar
Originally Posted by rkswyo View Post
I would say it is here to stay until they come up with something "better". I hate what they have done to the new diesels. The emmisions garbage is killing them. I have a 2008 Dodge 6.7 Cummins and it was terrible on mileage. I deleted all the power robbing, motor killing, mileage killing emmisions equipment and picked up 5 mpg. Engine oil stays cleaner and engine temperature has dropped. Really like the truck now.
Ditto here as well.Can't remember what programmer I got to go along with the delete but it's been a year now with absolutely zero problems,several long tows and it's not a daily driver,so it's been run at both ends of the spectrum.
Steve & Sue
2011 Crusader 320RLT
2008 Dodge Ram 3500 (CTD) DRW 4x4
RattVader is offline   Reply With Quote
Old 03-12-2012, 08:37 PM   #15
Coops1's Avatar
I didn't say he should or shouldn't modify the truck, I just said he'll love it. The OP said he's after a bigger truck and the new one fits the bill.
When my warranty is up I'll be taking a serious look at doing the delete as long as they don't bring in mandatory emissions testing.
26WRB - V-Lite
Denali HD LML
Old 03-16-2012, 04:01 PM   #16
Both the Ford's and Chev's have DEF for 2011 and the Dodge's will have it for 2012.
My F250 2011 CC longbed diesel gets 18.5 MPG empty and 13 GPG towing a 9,900 lbs 5er.
whj77372 is offline   Reply With Quote
Old 03-16-2012, 07:22 PM   #17
Coops1's Avatar
2013 is when Dodge will have it.
26WRB - V-Lite
Denali HD LML
Old 03-16-2012, 07:59 PM   #18
Now a "Top Member"
EdJunior's Avatar
This is a post I put on the Diesel Forum for my F-250:
"So, I just wanted to share my experience on my first real tow with the new truck. I have a 30' 5th wheel that loaded for our trip, came in around 10,500 pounds, maybe a bit more for this particular trip. We went from home (a little northeast of Houston) to Canyon Lake (just north of San Antonio). About 225 miles one way.
As I set the kingpin down on the hitch, the truck squatted about an inch and a half. Took just about 35 pounds in the air bags to get it level again. The ride was okay at first, but once I hit the bad stuff of Houston (concrete roads in not so good shape), the trailer started chucking and bouncing pretty good. I pumped up the air and at 55 pounds, I was able to get a decent ride. It did set the rear up a little high, but still plenty of clearance between the bed rails and the trailer.
The engine/transmission. All I can say is WOW! I'm not a big believer in the "night and day" thing, but this is just about as close as you can come. And that's even giving praise to the 6.4L I had. It was a good truck. This one is better. I set the cruise control at about 67 mph, and I could relax and let the truck do its thing. I think I remember only one time it had to come down out of 6th gear, and even that was so smooth and quiet, I barely noticed it. I don't think the boost ever went above the halfway mark (20). Ever! At 67 mph, it was pulling about 1600 - 1700 RPM and was so smooth and quiet it nearly put you to sleep!
On the trip to San Antonio, with a slight cross/head wind, I got 10.2 mpg. On the trip back, I managed 10.5 with a cross wind part of the trip. These mileages are on I-10 between Houston and San Antonio primarily. I did have some hilly areas once I got off of I-10 heading to Canyon Lake.
In the hilly area of Canyon Lake, the truck did superb. Once it found the gear it liked, it just did its thing. There was no strain, no noise and no problem. But keep in mind, these are not very big hills, though a couple were decent at least.
So, the good? I love those airbags. I have the Airlift wireless remote compressor, so I could adjust the pressure from the cab, while doing 60 mph down the highway. What a pleasure that was. I could find the right pressure for the conditions.
This engine is about as smooth as a baby's butt. Man is it nice. I really liked my 6.4L, but even on many overpasses, it would slip down a gear and was pretty noisy when it did it. The 6.7L never skipped a beat. As I said above, only once do I remember it hunting a gear, and I barely noticed it. Also, the 6.4L was almost always right at 20 or a little above on the boost, And the RPM's were up around 2000. I know some of that is due to the 3.73 I had on that truck as compared to the 3.31 on this one. But still, it is an amazing difference.
The bad? Man, I really can't think of anything bad to say. Maybe a little disappointment in the gas mileage towing the trailer, but nothing to write home about. And it's still better than the old truck."
Not towing, my daily driving, I'm getting almost 20mpg. I have about 6,500 miles on the odometer right now. I am thoroughly impressed with this truck. As far as the DEF, in the first 5,000 miles or so, it used just over half a tank. In the 2011 models, it only indicates "OK" or "Under Half a Tank". So I went to Sam's Club, bought a bottle of DEF (2.5 gallons) and topped it off. It is still reading "OK".
I'm not big on all the emissions crap that is tacked on the trucks these days, and I truly believe it held back a lot on the 6.4L from Ford, and the Cummins as well. But this new Ford diesel is a pretty amazing engine. Super quiet, no old diesel smell, a lot of power, and just a pleasure to drive.
Ed and Sharon
2010 Wildcat 28RKBS
2011 Ford F-250 XLT, 6.7L PSD
Ride-Rite Airbags and Airlift wireless remote compressor...nice!
Old 03-16-2012, 08:21 PM   #19
Sorry, I just don't see the improvement's claimed using DEF. You claim 10.5 towing a little 10,500 pounds. Heck I have seen 11.5 hand calculated towing 13,500 pounds with my bone stock 6.7L Dodge dually.
Old 03-17-2012, 09:17 AM   #20
Now a "Top Member"
EdJunior's Avatar
I didn't say I saw any improvement using DEF. My understanding of DEF is that it helps reduce the emissions further. Whether is affects performance or mileage, I can't say. I'm not going to take a chance with my warranty to find out. What I am saying is, the performance of the 2011 6.7L diesel over the 2008-2010 6.4L diesel is pretty significant. And I did also say that I was probably a little disappointed in the towing mileage. I know some of it can be attributed to the winds, but it seems I should have gotten a little better. Still, I'm not at all disappointed in any aspect of this new truck.
Ed and Sharon
2010 Wildcat 28RKBS
