02-26-2016, 07:30 PM
#41
Originally Posted by spock123
Gas Buddy is a good apps to have.
X2. The larger speed nozzles fill fast but can also make a mess!
2015 Denali Duramax 2500
2017 Coachmen 229TBS
02-26-2016, 07:55 PM
#42
Gas buddy
I just recently loaded "GAS BUDDY" into my smart phone and the app has selection for Regular, Midgrade, Premium, Diesel & E-85. It really helps to find the lowest price for Diesel. For example, truck stop on I-95 near Jacksonville, Fl. is $2.09.9 per gallon but down the exit ramp about 3/4 mile is diesel at a Speedway for $1.74.9. Quite a difference for driving 3/4 mile. as a prior post stated, the truck stop is not always the cheapest fuel even with the discount card from GOOD SAM.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2022 51 DAYS
[SIGPIC][/SI[SIGPIC]
02-26-2016, 07:58 PM
#43
Originally Posted by DAISY BOYKIN
I just recently loaded "GAS BUDDY" into my smart phone and the app has selection for Regular, Midgrade, Premium, Diesel & E-85. It really helps to find the lowest price for Diesel. For example, truck stop on I-95 near Jacksonville, Fl. is $2.09.9 per gallon but down the exit ramp about 3/4 mile is diesel at a Speedway for $1.74.9. Quite a difference for driving 3/4 mile. as a prior post stated, the truck stop is not the cheapest fuel even with the discount card from GOOD SAM.
Using Gas Buddy, you'll also find that T-stops are usually higher in price. If you're willing to drive a mile or two off the interstate, it can be $.05-.10 cheaper. I remember when truck stops use to be cheaper than others just based on volume discounts.
02-26-2016, 08:01 PM
#44
"While Google has not made an official announcement on this gas station enhancement, it looks like Apple is heading in the same direction. Apple recently announced that GasBuddy’s gas price information will soon be integrated within Apple Maps, and will roll out at some point in 2015." I wonder if this will be incorporated more into WAZE? WAZE currently has gas prices but not as good as GB.
02-26-2016, 08:38 PM
#45
Not to high jack the thread but when Walmart puts in a new store or gas station the fuel sure gets cheap for awhile
02-26-2016, 08:41 PM
#46
Who Dares, Wins
Never seen a Walmart gas station..
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
02-26-2016, 08:48 PM
#47
X2
02-26-2016, 08:50 PM
#48
They often partner with Murphy's USA for onsite stations.
02-26-2016, 09:07 PM
#49
Originally Posted by Kenny kustom
Bah ! Prepay !
Any canuks know how to pay at the pump in the states with a Canadian credit card ?
I have found it depends if they ask for a zip code if not you can just use like at home , if they want a zip you have to go in and pre pay a amount if you don't use that much you have to go in again and get a refund.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
02-26-2016, 09:45 PM
#50
Thanks for all the great information. Good to know truck lanes are an option and that aux tanks can be removed easily. I am looking forward to a diesel truck. Thanks again. Dan
02-26-2016, 10:08 PM
#51
Well get ready, they are already coming with the new stores. Walmart is going to put in there own gas stations. Murphy has been the stations at Walmart but no more. The Murphy stations will stay but now Walmart will be in competition with them. Between my house and Wilmington NC on I-40 a new Walmart store selling diesel for $1.69, at my house 35 miles away $1.95. Forget going in there with a camper. I'll be going by there on 5 March, going to buy a 100gl
02-27-2016, 09:23 AM
#52
Aux tanks
Originally Posted by cub22908
Thanks for the responses. An aux tank would be the perfect solution except that they are probably pretty much permanent installations. I do quite often use every inch of my bed hauling things. But I will do some research on this way of solving the problem. Dan
I installed 2 Sidekick 15gal tanks in my 2007 Dodge short bed.
https://titanfueltanks.com/shop/tita...-tank-5040015/
2013 Sanibel 3600 5th, 2007Dodge 2500 Cummins Turbo Diesel, 2WD, 4.10gears, Banks equipped, 18" factory rims
02-27-2016, 09:31 AM
#53
They fit well in the front of the bed.
02-27-2016, 05:52 PM
#54
I use the truck lanes and have never had a problem. Both Rams that I have owned take the larger truck pump and can fill a tank in no time flat.
02-27-2016, 08:27 PM
#55
Who Dares, Wins
Mine was tight but it fits in my Chevy.
2015 Chevy HD D-Max
02-28-2016, 12:27 PM
#56
I've used the truck lanes often when I owned my 2006 VW TDI Jetta Station wagon. It accepted truck nozzles and the truck lanes often were less busy mid-day than the passenger fueling areas.
One thing that folks don't recognize that may prevent a complete filling of their fuel tanks is that diesel fuel foams a lot! If you fill at a slower rate and and wait a minute before after the pump shots off you should be able to add an additional fuel. It takes a couple minutes of time but teh extra couple of gallons helps.
I try to fill the tank so it is visible in the fill hole. This is safe to do in diesels but overfilling is not recommended in gas vehicles because of evaporative canister emissions stuff.
02-28-2016, 01:04 PM
#57
I have a 50 gal tank/toolbox which might not work for 5ers but works well for me. It was easy to install and is much easier to remove, just 3 bolts and a worm clamp. Electric pump and filter remain attached under the bed.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
02-28-2016, 01:20 PM
#58
Originally Posted by Jim34RL
I have been pulling into truck stops ever since I purchased my 2008 Ram Mega Cab. I am will to pay the additional cost in fuel prices for the convince of using the truck stops. If I worried about every time I purchased fuel with the 5er attached I give up the RV life style. Another point on using major truck stop fueling places is the diesel fuel is fresh do to the large turn over rate of trucks buying diesel.
Most of the time we are traveling to a destination and this could be several days away from us. So we do not un-hook the 5er and for the convince of fueling up we just pull in to the truck stops right off the interstate.
We also use two different books to find diesel fuel in states that we are not familiar with. One is called the Next Exit and the other is called the RV'ERS friend.
If you haven't done so already, or if this thread is a duplicate please bear with me. Get a Good Scam Pilot\Flying J card. It will save you .06 per gallon on diesel fuel. I don't leave home without it.
02-28-2016, 02:17 PM
#59
That setup should work with 5er since it sets below the rails.
Off topic but I just checked your TT on youtube, that is one classic act, unique, and well thought out floor plan. Here is the video I looked at and if I was in market for TT this would be the one hands down.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
02-28-2016, 02:25 PM
#60
I e used them many times. No issues at all and they really fill up the truck quickly! Otherwise, I try to find a Flying J or TA and their diesel is on the outside lanes.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
